[GRASS-user] Status of ITZI in GRASS?
Venka venka.osgeo at gmail.com
Mon Sep 2 21:38:02 PDT 2024
Hi Thomas,
Some progress here in building a docker image with GRASS and itzi.
First of all, Thanks to Gérald and Markus for helping out with
this.
My experiment was done using Ubuntu_22.04 machine
a) Install docker
 > sudo apt-get update
 > sudo apt-get install docker-ce docker-ce-cli containerd.io
docker-buildx-plugin docker-compose-plugin
b) use my Dockerfile (attached) to build the Docker image
 > sudo docker build . -t itzi:grass_8_4_gui
It gave no compilation error for itzi
c) Run the Docker image
 > sudo docker run -it --rm --volume="$(pwd)/:/data"
--volume="/tmp/.X11-unix:/tmp/.X11-unix:rw" --env DISPLAY=$DISPLAY
--device="/dev/dri/card0:/dev/dri/card0" itzi:grass_8_4_gui grass --gui
d) Verify itzi version on GRASS command line
 > itzi version
e) Test the itzi tutorial at https://www.itzi.org/user-manual/
I have not run the entire tutorial but I guess it should work.
If you succeed with running the entire tutorial, let us know
Best
Venka
P.S. Could be useful if grass_with_itzi image is made available on
https://grass.osgeo.org/download/docker/
On 8/1/2024 4:26 AM, Thomas Adams wrote:
> Hi all;
> I have tried both approaches suggested by Venka and Markus and keep getting
> errors; I have:
> gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
> and I get this:
> cython -3 itzi/swmm/swmm_c.pyx itzi/flow.pyx
> /usr/lib/python3/dist-packages/scipy/__init__.py:146: UserWarning: A NumPy
> version >=1.17.3 and <1.25.0 is required for this version of SciPy
> (detected version 2.0.0
> I also have to use python3 not python in...
> python setup.py build
> Also, when I tried the approach suggested by Venka using conda, this messed
> up my GRASS installation with wxpython and the GUI would not launch. So, I
> had to remove conda and install wxpython
> A couple of years ago with a different Linux system and Itzi installed
> fine, so this is quite frustrating
> Tom
> On Thu, Jun 13, 2024 at 8:19 PM Venka via grass-user <
> grass-user at lists.osgeo.org> wrote:
>> Hi,
>> Thanks to Markus and Song for their feedback.
>> We succeeded in installing ITZI on Ubuntu 22.04
>> Steps to install GRASS and ITZI are as below;
>> ############ Install GRASS
>> #adding GRASS repository  into ubuntu22.04
>> #https://grass.osgeo.org/download/linux/#GRASS-GIS-current
>> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
>> sudo apt update
>> #installing GRASS 8.3.2
>> sudo apt-get install grass
>> #check grass well-done?
>> grass -v
>> grass -h
>> ########### Python virtual environment
>> conda info --envs
>> #conda create --name py38venka python=3.8
>> conda create --name py310venka python=3.10
>> conda activate py310venka
>> conda info --envs
>> ############installing itzi
>> https://itzi.readthedocs.io/en/latest/installation.html#installation-on-gnu-linux
>> #numpy required
>> conda install -c conda-forge pysal rioxarray cartopy
>> #cython, setuptools required
>> conda install -c conda-forge setuptools cython
>> #Compiling itzi first
>> unzip itzi-20.5.zip
>> cd itzi-master
>> python setup.py install
>> Best,
>> Venka
>> On 6/14/2024 1:55 AM, Markus Neteler via grass-user wrote:
>>> Hi,
>>> FWIW, I was able to compile ITZI today on Fedora 39 (gcc version
>>> 13.3.1 20240522; Python 3.12.3), using
>>> # install dependencies
>>> pip install numpy setuptools cython
>>> # generate some needed C files
>>> # build
>>> # install
>>> python setup.py install --user
>>> # test if it starts
>>> itzi version
>>> 20.5
>>> # pytest (see docs/prog_manual.rst)
>>> pytest -v
>>> Due to lack of time I could not continue yet.
>>> Perhaps I can try these days during the
>>> https://grasswiki.osgeo.org/wiki/GRASS_Community_Meeting_Prague_2024
>>> Best
>>> Markus
>>> Markus Neteler, PhD
>>> https://www.mundialis.de - company
>>> https://grass.osgeo.org - FOSS
>>> https://neteler.org - freelancing & blog
>>> grass-user mailing list
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
FROM osgeo/grass-gis:8.4.0-ubuntu_wxgui AS base
#https://itzi.readthedocs.io/en/latest/installation.html#installation-on-gnu-linux
RUN mkdir -p ~/miniconda3 \
    && wget https://repo.anaconda.com/miniconda/Miniconda3-latest-Linux-x86_64.sh -O ~/miniconda3/miniconda.sh \
    && bash ~/miniconda3/miniconda.sh -b -u -p ~/miniconda3 \
    && rm -rf ~/miniconda3/miniconda.sh \
    && ~/miniconda3/bin/conda init bash \
    && ls
#COPY --from=base /root/ /root/
RUN echo $PYTHONPATH \
    && export PATH=$PATH:~/miniconda3/bin/ \
    && grass -v \
    && source ~/.bashrc \
    && conda create --name py310venka python=3.10
RUN source ~/.bashrc \
         && conda install -y -c conda-forge pysal rioxarray cartopy setuptools cython six \
         && curl -o /tmp/itzi-20.5.tar.gz \
          https://files.pythonhosted.org/packages/61/e2/de2daf2437ff4006d809a9cf75ad7a55005719539a858712d908d0a540d7/itzi-20.5.tar.gz \
         && cd /tmp \
         && tar -xvf itzi-20.5.tar.gz \
         && cd itzi-20.5 \
         && cython -3 itzi/swmm/swmm_c.pyx itzi/flow.pyx \
         && python setup.py build \
         && python setup.py install
# To build the image from this file:
# sudo docker build . -t itzi:grass_8_4_gui
# To run command from within the container
# sudo docker run -it --rm --volume="$(pwd)/:/data" --volume="/tmp/.X11-unix:/tmp/.X11-unix:rw" --env DISPLAY=$DISPLAY --device="/dev/dri/card0:/dev/dri/card0" itzi:grass_8_4_gui grass --gui
# You can share folders from you local computer with the running Docker container using volumes (-v "$(pwd))
