[GRASS-user] Status of ITZI in GRASS?
Thomas Adams
tea3rd at gmail.com
Thu Sep 5 12:49:34 PDT 2024
Hi Venka,
I finally got time to run through your procedure -- thank you so much for
this! But, if I understand correctly, this only works within a docker
environment; is this correct?
I was able to successfully get through Step (d). However, the GRASS GUI
never launched and the process you provided installed GRASS 8.4, again,
within the docker environment. I was unable to work through the ITZI
tutorial due to these issues. I don't think this is a workable solution for
me. But, thank you!
Regards,
Tom
On Tue, Sep 3, 2024 at 12:38 AM Venka <venka.osgeo at gmail.com> wrote:
> Hi Thomas,
> Some progress here in building a docker image with GRASS and itzi.
> First of all, Thanks to Gérald and Markus for helping out with
> this.
> My experiment was done using Ubuntu_22.04 machine
> a) Install docker
> > sudo apt-get update
> > sudo apt-get install docker-ce docker-ce-cli containerd.io
> docker-buildx-plugin docker-compose-plugin
> b) use my Dockerfile (attached) to build the Docker image
> > sudo docker build . -t itzi:grass_8_4_gui
> It gave no compilation error for itzi
> c) Run the Docker image
> > sudo docker run -it --rm --volume="$(pwd)/:/data"
> --volume="/tmp/.X11-unix:/tmp/.X11-unix:rw" --env DISPLAY=$DISPLAY
> --device="/dev/dri/card0:/dev/dri/card0" itzi:grass_8_4_gui grass --gui
> d) Verify itzi version on GRASS command line
> > itzi version
> e) Test the itzi tutorial at https://www.itzi.org/user-manual/
> I have not run the entire tutorial but I guess it should work.
> If you succeed with running the entire tutorial, let us know
> Best
> Venka
> P.S. Could be useful if grass_with_itzi image is made available on
> https://grass.osgeo.org/download/docker/
> On 8/1/2024 4:26 AM, Thomas Adams wrote:
> > Hi all;
> > I have tried both approaches suggested by Venka and Markus and keep
> getting
> > errors; I have:
> > gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
> > and I get this:
> > cython -3 itzi/swmm/swmm_c.pyx itzi/flow.pyx
> > /usr/lib/python3/dist-packages/scipy/__init__.py:146: UserWarning: A
> NumPy
> > version >=1.17.3 and <1.25.0 is required for this version of SciPy
> > (detected version 2.0.0
> > I also have to use python3 not python in...
> > python setup.py build
> > Also, when I tried the approach suggested by Venka using conda, this
> messed
> > up my GRASS installation with wxpython and the GUI would not launch. So,
> I
> > had to remove conda and install wxpython
> > A couple of years ago with a different Linux system and Itzi installed
> > fine, so this is quite frustrating
> > Tom
> > On Thu, Jun 13, 2024 at 8:19 PM Venka via grass-user <
> > grass-user at lists.osgeo.org> wrote:
> >> Hi,
> >> Thanks to Markus and Song for their feedback.
> >> We succeeded in installing ITZI on Ubuntu 22.04
> >> Steps to install GRASS and ITZI are as below;
> >> ############ Install GRASS
> >> #adding GRASS repository into ubuntu22.04
> >> #https://grass.osgeo.org/download/linux/#GRASS-GIS-current
> >> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
> >> sudo apt update
> >> #installing GRASS 8.3.2
> >> sudo apt-get install grass
> >> #check grass well-done?
> >> grass -v
> >> grass -h
> >> ########### Python virtual environment
> >> conda info --envs
> >> #conda create --name py38venka python=3.8
> >> conda create --name py310venka python=3.10
> >> conda activate py310venka
> >> conda info --envs
> >> ############installing itzi
> https://itzi.readthedocs.io/en/latest/installation.html#installation-on-gnu-linux
> >> #numpy required
> >> conda install -c conda-forge pysal rioxarray cartopy
> >> #cython, setuptools required
> >> conda install -c conda-forge setuptools cython
> >> #Compiling itzi first
> >> unzip itzi-20.5.zip
> >> cd itzi-master
> >> python setup.py install
> >> Best,
> >> Venka
> >> On 6/14/2024 1:55 AM, Markus Neteler via grass-user wrote:
> >>> Hi,
> >>> FWIW, I was able to compile ITZI today on Fedora 39 (gcc version
> >>> 13.3.1 20240522; Python 3.12.3), using
> >>> # install dependencies
> >>> pip install numpy setuptools cython
> >>> # generate some needed C files
> >>> # build
> >>> # install
> >>> python setup.py install --user
> >>> # test if it starts
> >>> itzi version
> >>> 20.5
> >>> # pytest (see docs/prog_manual.rst)
> >>> pytest -v
> >>> Due to lack of time I could not continue yet.
> >>> Perhaps I can try these days during the
> >>> https://grasswiki.osgeo.org/wiki/GRASS_Community_Meeting_Prague_2024
> >>> Best
> >>> Markus
> >>> Markus Neteler, PhD
> >>> https://www.mundialis.de - company
> >>> https://grass.osgeo.org - FOSS
> >>> https://neteler.org - freelancing & blog
> >>> _______________________________________________
> >>> grass-user mailing list
> >>> https://lists.osgeo.org/mailman/listinfo/grass-user
Thomas E Adams, III
207 Chowning Place
Blacksburg, VA 24060
tea3rd at gmail.com (personal)
tea at terrapredictions.org (work)
1 (513) 739-9512 (cell)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240905/1e8c5340/attachment.htm>
