[GRASS-user] increase sqlite performance
Ivan Marchesini ivan.marchesini at gmail.com
Mon Jan 20 12:45:29 PST 2025
Hi guys,
I have a layer with millions of features. I need to join its table with
another large table based on a common column.
I tried to execute the join but it takes to much to run.
Reading around I understood that, in sqlite, performances can be
improved altering the "PRAGMA cache_size" which should be helpful if you
want to use more RAM and less disk i/o.
  (I'm working on a server where I have hundreds of Gb of ram and I
would like to exploit them)
I tested the following command:
db.execute sql="PRAGMA cache_size = 50000000;"
but then when I run:
db.select sql="PRAGMA cache_size;"
I get
DBMI-SQLite driver error:
Error in sqlite3_step():
database schema has changed
Unable to describe table:
ERROR: SQLite database connection is still busy
dbmi: Protocol error
Any suggestion about what I can do to solve this issue?
Thank you
Ivan
