[GRASS-user] Errors returned for r.stream.order
Ben Davies
ben.davies at dbca.wa.gov.au
Tue Mar 11 22:24:30 PDT 2025
OFFICIAL
Hello
OS = Win 10
GRASS GIS Version 8.3.0 64 Bit
I am attempting to create a stream classification and have tried the two approaches below.
Is there something wrong with my approach?
Try 1
gs.run_command('r.fill.dir', input=input_raster, output='fill', direction='flowdir_fill', overwrite=True)
gs.run_command('r.watershed', flags='sa', elevation='fill', threshold=500000, basin='raster_basin', accumulation='flowacc', stream='stream_raster_watershed', overwrite=True)
gs.run_command('r.stream.order', stream_rast='stream_raster_watershed', direction='flowdir_fill', elevation=input_raster, accumulation='flowacc', stream_vect='stream_vect', strahler='strahler', overwrite=True)
Try 2
gs.run_command('r.stream.extract', elevation=input_raster, threshold=stream_threshold, stream_raster='stream_raster', stream_vector='stream_vector', direction='flowdir_extract', overwrite=True)
gs.run_command('r.stream.order', stream_rast='stream_raster_watershed', direction='flowdir_extract', elevation=input_raster, accumulation='flowacc', stream_vect='stream_vect', strahler='strahler', overwrite=True)
The GRASS GIS system returns the following error message to me;
File
"F:\grassdata\hydro\PERMANENT\.tmp\unknown\4728.20.py", line
255, in <module>
main()
File
217, in main
File "C:\Program Files\GRASS GIS
8.3\etc\python\grass\script\core.py", line 466, in
run_command
return handle_errors(returncode, result=None, args=args,
kwargs=kwargs)
8.3\etc\python\grass\script\core.py", line 345, in
handle_errors
raise CalledModuleError(module=module, code=code,
returncode=returncode)
grass.exceptions.CalledModuleError: Module run
`r.stream.order --o stream_rast=stream_raster_watershed
direction=flowdir_extract elevation=dtm-002-004
accumulation=flowacc stream_vect=stream_vect
strahler=strahler` ended with an error.
The subprocess ended with a non-zero return code:
3221225781. See errors above the traceback or in the error
output.
Regards
Ben Davies
This message is confidential and is intended for the recipient named above. If you are not the intended recipient, you must not disclose, use or copy the message or any part of it. If you received this message in error, please notify the sender immediately by replying to this message, then delete it from your system.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20250312/2cccb1d6/attachment.htm>
