[GRASS-user] Errors returned for r.stream.order
    Maris Nartiss
    maris.gis at gmail.com
    Tue Mar 11 23:21:05 PDT 2025
Please provide also your computational region settings. Could be that
you are simply running out of RAM?
Māris.
trešd., 2025. g. 12. marts, plkst. 07:24 — lietotājs Ben Davies via
grass-user (<grass-user at lists.osgeo.org>) rakstīja:
> OFFICIAL
> Hello
> OS = Win 10
> GRASS GIS Version 8.3.0 64 Bit
> I am attempting to create a stream classification and have tried the two approaches below.
> Is there something wrong with my approach?
> Try 1
> gs.run_command('r.fill.dir', input=input_raster, output='fill', direction='flowdir_fill', overwrite=True)
> gs.run_command('r.watershed', flags='sa', elevation='fill', threshold=500000, basin='raster_basin', accumulation='flowacc', stream='stream_raster_watershed', overwrite=True)
> gs.run_command('r.stream.order', stream_rast='stream_raster_watershed', direction='flowdir_fill', elevation=input_raster, accumulation='flowacc', stream_vect='stream_vect', strahler='strahler', overwrite=True)
> Try 2
> gs.run_command('r.stream.extract', elevation=input_raster, threshold=stream_threshold, stream_raster='stream_raster', stream_vector='stream_vector', direction='flowdir_extract', overwrite=True)
> gs.run_command('r.stream.order', stream_rast='stream_raster_watershed', direction='flowdir_extract', elevation=input_raster, accumulation='flowacc', stream_vect='stream_vect', strahler='strahler', overwrite=True)
> The GRASS GIS system returns the following error message to me;
> Traceback (most recent call last):
>   File
> "F:\grassdata\hydro\PERMANENT\.tmp\unknown\4728.20.py", line
> 255, in <module>
>     main()
>   File
> 217, in main
>   File "C:\Program Files\GRASS GIS
> 8.3\etc\python\grass\script\core.py", line 466, in
> run_command
>     return handle_errors(returncode, result=None, args=args,
> kwargs=kwargs)
> 8.3\etc\python\grass\script\core.py", line 345, in
> handle_errors
>     raise CalledModuleError(module=module, code=code,
> returncode=returncode)
> grass.exceptions.CalledModuleError: Module run
> `r.stream.order --o stream_rast=stream_raster_watershed
> direction=flowdir_extract elevation=dtm-002-004
> accumulation=flowacc stream_vect=stream_vect
> strahler=strahler` ended with an error.
> The subprocess ended with a non-zero return code:
> 3221225781. See errors above the traceback or in the error
> output.
> Regards
> Ben Davies
> ________________________________
> This message is confidential and is intended for the recipient named above. If you are not the intended recipient, you must not disclose, use or copy the message or any part of it. If you received this message in error, please notify the sender immediately by replying to this message, then delete it from your system.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
