[GRASS-user] Errors returned for r.stream.order
Brendan
brendan.harmon at gmail.com
Wed Mar 12 03:41:38 PDT 2025
The flow accumulation from r.watershed should go into r.stream.exrract as
the input accumulation to calculate a stream raster and flow direction.
Then the flow accumulation, flow direction, stream raster, etc should go
into r.stream.order.
>From a glance, try one is missing r.stream.extract. Try two is missing
r.watershed. See my tutorial here:
https://baharmon.github.io/watersheds-in-grass/#stream-order
On Wed, Mar 12, 2025, 2:27 AM Maris Nartiss via grass-user <
grass-user at lists.osgeo.org> wrote:
> Please provide also your computational region settings. Could be that
> you are simply running out of RAM?
> Māris.
> trešd., 2025. g. 12. marts, plkst. 07:24 — lietotājs Ben Davies via
> grass-user (<grass-user at lists.osgeo.org>) rakstīja:
> > OFFICIAL
> > Hello
> > OS = Win 10
> > GRASS GIS Version 8.3.0 64 Bit
> > I am attempting to create a stream classification and have tried the two
> approaches below.
> > Is there something wrong with my approach?
> > Try 1
> > gs.run_command('r.fill.dir', input=input_raster, output='fill',
> direction='flowdir_fill', overwrite=True)
> > gs.run_command('r.watershed', flags='sa', elevation='fill',
> threshold=500000, basin='raster_basin', accumulation='flowacc',
> stream='stream_raster_watershed', overwrite=True)
> > gs.run_command('r.stream.order', stream_rast='stream_raster_watershed',
> direction='flowdir_fill', elevation=input_raster, accumulation='flowacc',
> stream_vect='stream_vect', strahler='strahler', overwrite=True)
> > Try 2
> > gs.run_command('r.stream.extract', elevation=input_raster,
> threshold=stream_threshold, stream_raster='stream_raster',
> stream_vector='stream_vector', direction='flowdir_extract', overwrite=True)
> direction='flowdir_extract', elevation=input_raster,
> accumulation='flowacc', stream_vect='stream_vect', strahler='strahler',
> overwrite=True)
> > The GRASS GIS system returns the following error message to me;
> > Traceback (most recent call last):
> > File
> > "F:\grassdata\hydro\PERMANENT\.tmp\unknown\4728.20.py", line
> > 255, in <module>
> > main()
> > File
> > 217, in main
> > File "C:\Program Files\GRASS GIS
> > 8.3\etc\python\grass\script\core.py", line 466, in
> > run_command
> > return handle_errors(returncode, result=None, args=args,
> > kwargs=kwargs)
> > 8.3\etc\python\grass\script\core.py", line 345, in
> > handle_errors
> > raise CalledModuleError(module=module, code=code,
> > returncode=returncode)
> > grass.exceptions.CalledModuleError: Module run
> > `r.stream.order --o stream_rast=stream_raster_watershed
> > direction=flowdir_extract elevation=dtm-002-004
> > accumulation=flowacc stream_vect=stream_vect
> > strahler=strahler` ended with an error.
> > The subprocess ended with a non-zero return code:
> > 3221225781. See errors above the traceback or in the error
> > output.
> > Regards
> > Ben Davies
> > ________________________________
> > This message is confidential and is intended for the recipient named
> above. If you are not the intended recipient, you must not disclose, use or
> copy the message or any part of it. If you received this message in error,
> please notify the sender immediately by replying to this message, then
> delete it from your system.
> > grass-user mailing list
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20250312/2be5932b/attachment-0001.htm>
