[GRASSweb-list]markus: web/grass5/binary/linux README.html,1.3,1.4
grass at intevation.de
Thu Aug 22 02:48:21 EDT 2002
Author: markus
Update of /grassrepository/web/grass5/binary/linux
In directory doto:/tmp/cvs-serv30698/linux
Modified Files:
README.html
Log Message:
fixes
Index: README.html
RCS file: /grassrepository/web/grass5/binary/linux/README.html,v
retrieving revision 1.3
retrieving revision 1.4
diff -u -d -r1.3 -r1.4
--- README.html 29 Jun 2002 08:42:09 -0000 1.3
+++ README.html 22 Aug 2002 06:48:19 -0000 1.4
@@ -16,9 +16,9 @@
grass5_i686-pc-linux-gnu_install.sh
Then you only need to type the following after
-you ftp it (example!):
+you downloaded it (example!):
- sh grass5_i686-pc-linux-gnu_install.sh grass5pre3_linuxbin.tar.gz
+ sh grass5_i686-pc-linux-gnu_install.sh grass5pre3_linuxbin.tar.gz [dest_dir] [bin_dir]
This will create the necessary directories and
files for you to run GRASS. The default install path is
@@ -27,6 +27,24 @@
To install in a different directory, specify it in the
command line:
+Usage:
+ sh grass5_i686-pc-linux-gnu_install.sh grass_binpackage.tar.gz [dest_dir] [bin_dir]
+ with:
+ grass_binpackage : name of GRASS 5 binary package
+ [dest_dir] - optional: FULL path name to the installation directory
+ (default: /usr/local/grass5/)
+ [bin_dir] - optional: FULL path name to the grass binary directory
+ (default: /usr/local/bin/)
+ Notes: 1) Only the grass executable file is stored here
+ 2) If you want to change the binary directory only
+ then you need to specify the destination
+ directory as well
+You may need login as root for installation.
+Example (changing the destdir, keeping the bindir):
sh grass5_i686-pc-linux-gnu_install.sh grass5pre3_linuxbin.tar.gz /opt/grass5
@@ -89,16 +107,17 @@
versions of GRASS if you have it available.
+Please help us and report eventually bugs using the bug report form:
+<a href=http://grass.itc.it/bugtracking/bugreport.html>go here!</a>
-If you experience any problems, please email
-us at:
+If you experience any problems, please email us at:
- http://grass.itc.it/support.html
International GRASS Users Mailing list
+ http://grass.itc.it/support.html
+or
+ weblist at grass.itc.it
-Please help us and report eventually bugs:
-Bug report form:
-<a href=http://grass.itc.it/bugtracking/bugreport.html>go here!</a>
</pre>
More information about the grass-web
