[GRASSweb-list]markus: web/grass5/binary/irix README.html,1.1.1.1,1.2
grass at intevation.de grass at intevation.de
Thu Aug 22 02:48:21 EDT 2002
Author: markus
Update of /grassrepository/web/grass5/binary/irix
In directory doto:/tmp/cvs-serv30698/irix
Modified Files:
	README.html
Log Message:
fixes
Index: README.html
RCS file: /grassrepository/web/grass5/binary/irix/README.html,v
retrieving revision 1.1.1.1
retrieving revision 1.2
diff -u -d -r1.1.1.1 -r1.2
--- README.html	24 Nov 2001 18:28:02 -0000	1.1.1.1
+++ README.html	22 Aug 2002 06:48:19 -0000	1.2
@@ -1,20 +1,20 @@
 <HTML> <BODY BGCOLOR=#FFFFFF>
 <pre>
 This directory contains the SGI/IRIX binary code for
-GRASS 5.0 beta X in gzipped tar format.
+GRASS 5.0 pre X in gzipped tar format.
 Installation:
-1. get the large (55 mb) file
-     grass5.0betaX_IRIX_bin.tar.gz
+1. get the large (65 MB) file
+     grass5.0preX_IRIX_bin.tar.gz
    which is the whole binary in a single file.
 2. get the installation script
      grass5install.sh
 Then you only need to type the following after
-you ftp it (example!):
+you downloaded it (example!):
-  sh grass5install.sh grass5.0beta11_IRIX_bin.tar.gz [dest_dir] [bin_dir]
+  sh grass5install.sh grass5.0pre5_IRIX_bin.tar.gz [dest_dir] [bin_dir]
 This will create the necessary directories and
 files for you to run GRASS. The default install path is
@@ -28,25 +28,28 @@
       with:
         grass_binpackage : name of GRASS 5 binary package
         [dest_dir] - optional: FULL path name to the installation directory
-                     (default: /usr/local/grass-5.0b/)
+                     (default: /usr/local/grass5/)
         [bin_dir] - optional: FULL path name to the grass binary directory
                      (default: /usr/local/bin/)
                      Notes: 1) Only the grass executable file is stored here
-                            2) If you want to change the binary directory
-only
+                            2) If you want to change the binary directory only
                                then you need to specify the destination
                                directory as well
 You may need login as root for installation.
 Example (changing the destdir, keeping the bindir):
-  sh grass5install.sh grass5.0beta11_IRIX_bin.tar.gz /opt/grass5
+  sh grass5install.sh grass5.0pre5_IRIX_bin.tar.gz /opt/grass5
 After installation start GRASS with
    grass5
+To get help, enter
+   grass5 -help
 The user interface is started within GRASS:
    tcltkgrass&
@@ -82,7 +85,7 @@
 of GISBASE in etc/paint/driver.rsh.
-3) If you plan to use v.digspline and have any
+3) If you plan to use v.digit and have any
 digitizers copy the file etc/digcap.sampl to
 etc/digcap and edit it accordingly.
@@ -93,19 +96,21 @@
 The binary version does not come with any data or
 documentation (except for on-line man pages).  You will
 need to acquire whatever documents you like from the GRASS
-Research Group FTP server.  Sample data is also available
-from the FTP site, or you may use data from previous
+Development Team web server/FTP site.  Sample data is also
+available from the site, or you may use data from previous
 versions of GRASS if you have it available.
-Please help us and report bugs:
-The bug report form is at:
-<a href=http://www.geog.uni-hannover.de/grass/bugtracking/bugreport.html>go here!</a>
+Please help us and report bugs using the bug report form at:
+<a href=http://grass.itc.it/bugtracking/bugreport.html>go here!</a>
-If you experience any problems, please email
-us at:
+If you experience any problems, please email us at:
-  grass at baylor.edu
+ International GRASS Users Mailing list
+ http://grass.itc.it/support.html
+or
+  weblist at grass.itc.it
 </pre>
More information about the grass-web mailing list
