[GRASSweb-list]markus: web firsttime.html,1.15,1.16 general.html,1.12,1.13 index2.html,1.68,1.69 newsarchive.html,1.6,1.7 wingrass.html,1.4,1.5 5.0winport.info.html,1.9,NONE
grass at intevation.de
Fri Jun 28 07:50:42 EDT 2002
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv28119
Modified Files:
firsttime.html general.html index2.html newsarchive.html
wingrass.html
Removed Files:
Log Message:
changed to a useful file name
Index: firsttime.html
RCS file: /grassrepository/web/firsttime.html,v
retrieving revision 1.15
retrieving revision 1.16
diff -u -d -r1.15 -r1.16
--- firsttime.html 19 Jun 2002 12:23:40 -0000 1.15
+++ firsttime.html 28 Jun 2002 11:50:39 -0000 1.16
@@ -51,7 +51,7 @@
like:
<ul>
<li>UNIX environment through a graphical user interface and shell in X-Windows
-<li><a href="5.0winport.info.html">MS-Windows</a> (NT/2000/XP with Cygwin) for the experimental winGRASS port
+<li><a href="wingrass.html">MS-Windows</a> (NT/2000/XP with Cygwin) for the experimental winGRASS port
<li><a href="http://www.openosx.com/grass/">MacOS X</a>
</ul>
Here are some example screenshots on GRASS running under Linux, Windows/Cygwin and MacOS X.
Index: general.html
RCS file: /grassrepository/web/general.html,v
retrieving revision 1.12
retrieving revision 1.13
diff -u -d -r1.12 -r1.13
--- general.html 10 Jun 2002 09:10:11 -0000 1.12
+++ general.html 28 Jun 2002 11:50:39 -0000 1.13
@@ -46,7 +46,7 @@
<p><font face="Arial,Helvetica">The GRASS GIS is run through the use of
either a standardized command line input, or an <a href="grassgui.html">Graphical
User Interface</a> based on Tcl and Tk. GRASS is also supported under
-<a href="5.0winport.info.html">Windows NT/2000 running Cygwin</a> (experimental).
+<a href="wingrass.html">Windows NT/2000 running Cygwin</a> (experimental).
GRASS can be used in shell scripts which allow users and programmers to
create new applications and link GRASS to other software packages. For
programming a fully documented C-API (> 800 GIS library functions) is provided.
Index: index2.html
RCS file: /grassrepository/web/index2.html,v
retrieving revision 1.68
retrieving revision 1.69
diff -u -d -r1.68 -r1.69
--- index2.html 28 Jun 2002 09:38:23 -0000 1.68
+++ index2.html 28 Jun 2002 11:50:39 -0000 1.69
@@ -74,7 +74,7 @@
<a href="grass_addons.html">Add-Ons</a><br>
<a href="data.html">Sample Data</a><br>
<a href="gdp/online.html">Manuals</a><br>
- <a href="5.0winport.info.html">MS-Windows port</a><br>
+ <a href="wingrass.html">MS-Windows port</a><br>
<a href="grasshandheld.html">Handhelds</a><br>
<a href="acquire.html">CDROMs</a><br>
<p />
Index: newsarchive.html
RCS file: /grassrepository/web/newsarchive.html,v
retrieving revision 1.7
diff -u -d -r1.6 -r1.7
--- newsarchive.html 28 Jun 2002 09:36:17 -0000 1.6
+++ newsarchive.html 28 Jun 2002 11:50:39 -0000 1.7
@@ -65,7 +65,7 @@
support implemented in gstat</a>. Gstat is a computer program for geostatistical
modelling, prediction and simulation.
<li>16. April 2001: New <a href=http://water.baylor.edu/forum/>GRASS GIS online forum</a>!
-<li>11. April 2001: Experimental <a href=5.0winport.info.html>winGRASS
+<li>11. April 2001: Experimental <a href=wingrass.html>winGRASS
binaries</a> (GRASS on WindowsNT/2000) arrived!
<li>6. April 2001: Formation of German grass user group: <a
href=http://www.grass-verein.de>GRASS Anwender-Vereinigung e.V</a>, a tax-exempt charity organisation
Index: wingrass.html
RCS file: /grassrepository/web/wingrass.html,v
retrieving revision 1.4
retrieving revision 1.5
diff -u -d -r1.4 -r1.5
--- wingrass.html 13 May 2002 13:59:54 -0000 1.4
+++ wingrass.html 28 Jun 2002 11:50:39 -0000 1.5
@@ -1,38 +1,116 @@
+<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
- <title>GRASS to Windows port page</title>
+ <meta name="GENERATOR" content="Mozilla/4.7 [de] (WinNT; I) [Netscape]">
+ <meta name="Author" content="Andreas C. Lange">
+ <meta name="KeyWords" content="GRASS, GIS, Windows, Porting, cygwin, Microsoft">
+ <title>GRASS GIS 5.0 port to Windows Information</title>
</head>
<body text="#000000" bgcolor="#FFFFFF">
-<FONT FACE="Arial, Helvetica" size="3">
+<center>
+<h1>
-<H1>
-<a href=index2.html><IMG SRC="images/grass.smlogo.gif" ALT="grasslogo"
-border=0 ALIGN=CENTER></a>
-winGRASS GIS mailing list</H1>
+<hr SIZE=3 NOSHADE WIDTH="100%"><font face="Arial, Helvetica"><font size=+2>GRASS
+5.0 port to Microsoft Windows</font></font></h1></center>
-<p> To coordinate ideas and work on GRASS GIS to MS-Windows, this
-mailing list is established. Feel free to subscribe and participate:
+<center><a href="demos/winGRASS_big.png"><img SRC="demos/winGRASS.png" ></a></center>
+<p>
+<p><font face="Arial, Helvetica"><font size=+0>Currently we are porting
+the GRASS GIS 5.0 to MS Windows (NT, 2000 Professional, XP) using the <a href="http://sources.redhat.com/cygwin/download.html">cygwin
+tools</a>. The source code is identical to the UNIX version as the GRASS
+source code is rather platform independent. If you want to compile yourself,
+we recommend to get the latest GRASS sources from our <a href="grasscvs.html">CVS-Server</a>.</font></font>
+<p><font face="Arial, Helvetica"><font size=+0>You are encouraged to use
+this experimental version and assist to identify and help fixing the few
+bugs still in this version. Following problems are to be addressed
+in a future release:</font></font>
<ul>
-<li><a href=http://grass.itc.it/mailman/listinfo/wingrass>winGRASS Mailing List (un)subscription page</a>
-<li><a href=http://grass.itc.it/pipermail/wingrass/>winGRASS mailing list archives</a>
-<li><a href=searchgrass.html>Search</a> Mailing List
+<li>
+<font face="Arial, Helvetica"><font size=+0>stabilize the native windows graphical
+output window to display maps;</font></font></li>
+<li>
+<font face="Arial, Helvetica"><font size=+0>have a native windows menu
+user interface </font></font></li>
+<li>
+<font face="Arial, Helvetica"><font size=+0>get NVIZ working
+(problem is the limited path support of TclTk for Cygwin).</font></font></li>
</ul>
-<!-- hidden links to make htdig and Google search the list archives (new and old): -->
-<a href=http://grass.itc.it/pipermail/wingrass/><font color=white>x</font></a>
+<font face="Arial, Helvetica"><font size=+0>The <b>graphical output screen</b>
+(based on XDRIVER) has been the major problem to port GRASS. The system
+is now working with the XFree86 Server or the StarNet X-Win Server
+as well as the generic Windows driver. For the <b>menu system</b> (only
+supported for winGRASS with Xdriver)
+currently the tcl/tk based tcltkgrass program is used. The native <b>menu
+system</b> (probably based on tcl/tk or python) will take more time.</font></font>
+<p><font face="Arial, Helvetica"><font size=+0>We are searching for developers
+and testers to assist in finalizing the GRASS-Windows port: If you are
+(somewhat) experienced, join the <a href="grassdevel.html">development
+team</a> to speed up the port. If you have questions or want to discuss
+the development, please subscribe to the <b><a href="wingrass.html">winGRASS
+mailing list.</a> </b>Before reporting bugs to the list, please visit the
+bug reporting system and read the manuals and old posts to the mailing
+lists. See <a href="bugtracking/bugreport.html">here</a> for report a bug.</font></font>
-<b>Further Information and downloads:</b>
+<p>
+<b><font face="Arial, Helvetica"><font size=+0>Download pre-compiled winGRASS
+binaries:</font></font></b>
<ul>
-<li><a href=5.0winport.info.html>winGRASS port status info and download page</a>
-<li><a href=grassdevel.html#prog>GRASS 5 Programmer's Manual</a> (PDF, 2 MB)
+<li>
+<font face="Arial, Helvetica"><font size=+0>Download <a href="grass5/binary/windows_cygnus/">precompiled
+package for the GRASS port to Windows</a> We provide
+two versions:
+<ul>
+<li>
+<font face="Arial,Helvetica">winGRASS with Xserver requirement:
+wingrass_xserver/</font></li>
+<li>
+<font face="Arial,Helvetica">winGRASS without Xserver requirement:
+wingrass_generic/
+(eventually more limited in functionality)</font></li>
</ul>
-<hr>
-<address>
-<a href=mailto:weblist at grass.itc.it>GRASS Development Team</a>
-</address>
+</font></font><br>
+<font face="Arial, Helvetica"><font size=+0><b>NOTE:</b> Supported are Windows NT (SP 3 or above), Windows 2000 Professional
+and XP.</font></font>
+<li>
+<font face="Arial, Helvetica"><font size=+0><a href="grass5/binary/windows_cygnus/cygwin_grass50bininstall.html">Instructions
+to install the precompiled winGRASS package.</a></font></font></li>
+</ul>
+<p><b><font face="Arial, Helvetica"><font size=+0>Download source code
+(to compile GRASS from scratch on Windows):</font></font></b>
+<ul>
+<li>
+<font face="Arial, Helvetica"><font size=+0>Get the latest <a href="download.html">GRASS
+5 sources.</a></font></font></li>
+<li>
+<font face="Arial, Helvetica"><font size=+0><a href="grass5/binary/windows_cygnus/cygwin_grass50compile.html">Instructions
+on how to compile</a> GRASS 5.0 with the cygnus tools.</font></font></li>
+</ul>
+<font face="Arial, Helvetica"><h3>FAQ (related to Cygwin)</h3></font>
+<ul>
+<li><font face="Arial, Helvetica"><a href=http://cygwin.com/faq/faq_toc.html>Cygwin FAQ</a></font>
+<li><font face="Arial, Helvetica"><a href=http://xfree86.cygwin.com/docs/faq/cygwin-xfree-faq.html>Xfree/Cygwin FAQ</a></font>
+</ul>
+<center><a href="index2.html"><img SRC="images/gbanner_small.jpg" BORDER=0 ></a>
+<br><font face="Arial, Helvetica"><font color="#000000"><font size=-2>Send
+your winGRASS related email to <a href="mailto:John.Huddleston at usda.gov">John
+Huddleston</a> or <a href="mailto:Andreas.Lange at Rhein-Main.de">Andreas
+Lange</a></font></font></font></center>
+</body>
</html>
--- 5.0winport.info.html DELETED ---
More information about the grass-web
