[GRASSweb-list]markus: web/grass51 index.html,1.42,1.43
grass at intevation.de
Fri Nov 29 04:06:11 EST 2002
Author: markus
Update of /grassrepository/web/grass51
In directory doto:/tmp/cvs-serv23746
Modified Files:
Log Message:
Radim does a great job...
Index: index.html
RCS file: /grassrepository/web/grass51/index.html,v
retrieving revision 1.42
retrieving revision 1.43
diff -u -d -r1.42 -r1.43
--- index.html 27 Nov 2002 12:31:36 -0000 1.42
+++ index.html 29 Nov 2002 09:06:09 -0000 1.43
@@ -29,37 +29,63 @@
a modified NVIZ and a few database management tools.
DBMS is now integral part of the system.
<ul>
-<li><b>PostGIS support</b> implemented: <a
- href=http://www.rcost.unisannio.it/antoniol/students/PostGrass/>read
- documentation</a> (and <a href=http://postgis.refractions.net/>here</a> is
- the PostGIS site)</li>
-<li>
-<b>Shortest path vector networking</b> (<a href=http://mpa.itc.it/radim/g51/d.path.jpg>screenshot</a>) - based on
-<a href=../dglib/>DGLIB (Directed Graph Library)</a></li>
+<li>Vector library (geometry):
+<ul>
+ <li>
+ <b>multiformat</b> - also external data formats
+ supported (SHAPE-file, PostGIS) without the need of data conversion</li>
-<li>
-<b>multilayer</b> - features in one vector
-may represent more layers and may be linked to more external tables</li>
+ <li>Optional <b>PostGIS support</b> implemented for geometry storage: <a
+ href=http://www.rcost.unisannio.it/antoniol/students/PostGrass/>read
+ documentation</a> (and <a href=http://postgis.refractions.net/>here</a> is
+ the PostGIS site), allows for multiuser write access</li>
+ <li>spatial index - v.build (v.support) accelerated from hours to
+ seconds</li>
+</ul>
-<li>
-<b>multiattribute</b> - attributes saved
-in external RDBMS: supported are DBF, ODBC, PostgreSQL and mySQL</li>
+<li>Database Management Interface (attributes):
+<ul>
+ <li>
+ <b>multiattribute</b> - attributes optionally saved
+ in external RDBMS: supported are DBF, ODBC, PostgreSQL and mySQL</li>
-<li>
-<b>3D</b> - optional 3D vectors may be created
-(TIN)</li>
+ <li>
+ <b>multilayer</b> - features in one vector may represent one or several
+ layers and may be linked to one or several external tables</li>
-<li>
-<b>multiformat</b> - external data formats
-supported (shapefile, PostGIS)</li>
+ <li>
+ <b>3D</b> - optional 3D vectors may be created (see <a
+ href=http://mpa.itc.it/radim/g51/chaloupky1.png>screenshot</a>)
+ (eg TINs), already supported in NVIZ</li>
+</ul>
-<li>
-<b>GUI generated by front end on runtime</b>
-and display manager (<a
-href=http://mpa.itc.it/radim/g51/>screenshots</a>)</li>
+<li>Applications/Misc:
+<ul>
+ <li>SQL queries/selects supported by some modules such as d.vect,
+ v.extract and v.surf.rst</li>
+ <li>
+ <b>Shortest path vector networking</b> (<a href=http://mpa.itc.it/radim/g51/d.path.jpg>screenshot</a>) - based on
+ <a href=../dglib/>DGLIB (Directed Graph Library)</a>, costs may be assigned
+ both to nodes and arcs (and also different in both directions of a vector
+ line)</li>
+ <li>new v.digit with GUI under construction (<a
+ href=http://mpa.itc.it/radim/g51/v.digit3.png>screenshot</a>)</li>
+ <li>export any <a href=http://gdal.velocet.ca/projects/opengis/>OGR
+ format</a> for which write access is supported by OGR (including
+ attributes, if supported by format). Currently Shapefile, TIGER, MapInfo
+ and GML. PostGIS and DGN should be soon available</li>
+ <li>
+ <b>GUI generated by front end on runtime</b>
+ and display manager (<a
+ href=http://mpa.itc.it/radim/g51/>screenshots</a>)</li>
+</ul>
</ul>
-The 5.1 code requires the experimental tree
+The 5.1 code (still) requires the experimental tree
of GRASS 5.0 code (note: the preX release won't work!) as it will be partly
merged into the 5.1 directory structure during compilation. From time to
time more code will be migrated into 5.1.
More information about the grass-web
