[GRASSweb-list]markus: web/grass51 index.html,1.43,1.44
    grass at intevation.de
    Fri Nov 29 04:12:49 EST 2002
Author: markus
Update of /grassrepository/web/grass51
In directory doto:/tmp/cvs-serv23894
Modified Files:
Log Message:
cosmetics
Index: index.html
RCS file: /grassrepository/web/grass51/index.html,v
retrieving revision 1.43
retrieving revision 1.44
diff -u -d -r1.43 -r1.44
--- index.html	29 Nov 2002 09:06:09 -0000	1.43
+++ index.html	29 Nov 2002 09:12:47 -0000	1.44
@@ -39,7 +39,7 @@
   href=http://www.rcost.unisannio.it/antoniol/students/PostGrass/>read
   documentation</a> (and <a href=http://postgis.refractions.net/>here</a> is
   the PostGIS site), allows for multiuser write access</li>
- <li>spatial index - v.build (v.support) accelerated from hours to
+ <li><b>spatial index</b> - v.build (v.support) accelerated from hours to
   seconds</li>
 </ul>
@@ -54,14 +54,14 @@
  layers and may be linked to one or several external tables</li>
  <li>
- <b>3D</b> - optional 3D vectors may be created (see <a
+ <b>3D vectors</b> may be created (see <a
   href=http://mpa.itc.it/radim/g51/chaloupky1.png>screenshot</a>)
  (eg TINs), already supported in NVIZ</li>
 </ul>
 <li>Applications/Misc:
 <ul>
- <li>SQL queries/selects supported by some modules such as d.vect,
+ <li><b>SQL queries/selects</b> supported by some modules such as d.vect,
  v.extract and v.surf.rst</li>
  <li>
@@ -70,17 +70,17 @@
  both to nodes and arcs (and also different in both directions of a vector
  line)</li>
- <li>new v.digit with GUI under construction (<a
+ <li>new <b>v.digit with GUI</b> under construction (<a
    href=http://mpa.itc.it/radim/g51/v.digit3.png>screenshot</a>)</li>
- <li>export any <a href=http://gdal.velocet.ca/projects/opengis/>OGR
-  format</a> for which write access is supported by OGR (including
+ <li><b>export of any <a href=http://gdal.velocet.ca/projects/opengis/>OGR
+  format</a></b> for which write access is supported by OGR (including
   attributes, if supported by format).  Currently Shapefile, TIGER, MapInfo
   and GML. PostGIS and DGN should be soon available</li>
  <li>
  <b>GUI generated by front end on runtime</b>
- and display manager (<a
+ and <b>display manager</b> (<a
  href=http://mpa.itc.it/radim/g51/>screenshots</a>)</li>
 </ul>
 </ul>
More information about the grass-web
