[GRASSweb-list]markus: web/grass5/binary/irix README.html,1.2,1.3
grass at intevation.de grass at intevation.de
Mon Oct 28 05:19:48 EST 2002
Author: markus
Update of /grassrepository/web/grass5/binary/irix
In directory doto:/tmp/cvs-serv3386/binary/irix
Modified Files:
	README.html
Log Message:
removed 'pre's
Index: README.html
RCS file: /grassrepository/web/grass5/binary/irix/README.html,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- README.html	22 Aug 2002 06:48:19 -0000	1.2
+++ README.html	28 Oct 2002 10:19:46 -0000	1.3
@@ -1,12 +1,12 @@
 <HTML> <BODY BGCOLOR=#FFFFFF>
 <pre>
 This directory contains the SGI/IRIX binary code for
-GRASS 5.0 pre X in gzipped tar format.
+GRASS 5.0.X in gzipped tar format.
 Installation:
 1. get the large (65 MB) file
-     grass5.0preX_IRIX_bin.tar.gz
+     grass5.0.X_IRIX_bin.tar.gz
    which is the whole binary in a single file.
 2. get the installation script
      grass5install.sh
@@ -14,7 +14,7 @@
 Then you only need to type the following after
 you downloaded it (example!):
-  sh grass5install.sh grass5.0pre5_IRIX_bin.tar.gz [dest_dir] [bin_dir]
+  sh grass5install.sh grass5.0.0_IRIX_bin.tar.gz [dest_dir] [bin_dir]
 This will create the necessary directories and
 files for you to run GRASS. The default install path is
@@ -39,7 +39,7 @@
 You may need login as root for installation.
 Example (changing the destdir, keeping the bindir):
-  sh grass5install.sh grass5.0pre5_IRIX_bin.tar.gz /opt/grass5
+  sh grass5install.sh grass5.0.0_IRIX_bin.tar.gz /opt/grass5
 After installation start GRASS with
More information about the grass-web mailing list
