[GRASSweb-list]markus: web/grass5/binary/linux README.html,1.4,1.5
grass at intevation.de grass at intevation.de
Mon Oct 28 05:19:48 EST 2002
Author: markus
Update of /grassrepository/web/grass5/binary/linux
In directory doto:/tmp/cvs-serv3386/binary/linux
Modified Files:
	README.html
Log Message:
removed 'pre's
Index: README.html
RCS file: /grassrepository/web/grass5/binary/linux/README.html,v
retrieving revision 1.4
retrieving revision 1.5
diff -u -d -r1.4 -r1.5
--- README.html	22 Aug 2002 06:48:19 -0000	1.4
+++ README.html	28 Oct 2002 10:19:46 -0000	1.5
@@ -1,7 +1,7 @@
 <HTML> <BODY BGCOLOR=#FFFFFF>
 <pre>
 This directory contains the Linux (x86/Intel) binary code for
-GRASS 5.0 pre X in gzipped tar format.
+GRASS 5.0.X in gzipped tar format.
 It was precompiled on Linux based on libc.so.6 aka glibc2.2
 You will need Redhat 7.0, Suse 7.0 or above.
@@ -10,7 +10,7 @@
 Installation:
 1. get the large (32 mb) file
-     grass5.0preX_linuxbin.tar.gz
+     grass5.0.X_linuxbin.tar.gz
    which is the whole binary in a single file.
 2. get the installation script
      grass5_i686-pc-linux-gnu_install.sh
@@ -18,7 +18,7 @@
 Then you only need to type the following after
 you downloaded it (example!):
-  sh grass5_i686-pc-linux-gnu_install.sh grass5pre3_linuxbin.tar.gz [dest_dir] [bin_dir]
+  sh grass5_i686-pc-linux-gnu_install.sh grass5.0.0_linuxbin.tar.gz [dest_dir] [bin_dir]
 This will create the necessary directories and
 files for you to run GRASS. The default install path is
@@ -45,7 +45,7 @@
 You may need login as root for installation.
 Example (changing the destdir, keeping the bindir):
-  sh grass5_i686-pc-linux-gnu_install.sh grass5pre3_linuxbin.tar.gz /opt/grass5
+  sh grass5_i686-pc-linux-gnu_install.sh grass5.0.0_linuxbin.tar.gz /opt/grass5
 After installation start GRASS with
More information about the grass-web mailing list
