[GRASSweb-list]markus: web/statsgrass grass_r_insthints.html,1.2,1.3
grass at intevation.de
Thu Oct 31 10:13:08 EST 2002
Author: markus
Update of /grassrepository/web/statsgrass
In directory doto:/tmp/cvs-serv15820
Modified Files:
Log Message:
fixes
Index: grass_r_insthints.html
RCS file: /grassrepository/web/statsgrass/grass_r_insthints.html,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- grass_r_insthints.html 31 Oct 2002 14:41:11 -0000 1.2
+++ grass_r_insthints.html 31 Oct 2002 15:13:06 -0000 1.3
@@ -26,7 +26,7 @@
</pre>
<hr>
-<h2>A) INSTALLATION on UN*X compilant SYSTEMS (Linux etc)</h2>
+<h2>A) Installation on UN*X compilant systems (Linux etc)</h2>
<pre>
There are a number of configure flags that may be used to help
@@ -51,7 +51,7 @@
/usr/bin/R CMD INSTALL --configure-args=--grass5=/opt/ssi/bin/grass5 GRASS_0.1-9.tar.gz
-UNINSTALLATION on UN*X compilant SYSTEMS (Linux etc)
+<b>UNINSTALLATION on UN*X compilant SYSTEMS (Linux etc)</b>
The following command uninstalls the GRASS/R interface (GRASS remains
untouched of course):
@@ -61,13 +61,12 @@
<hr>
-<h2>B) INSTALLATION on MS-Windows SYSTEM (XP, 2000 etc)</h2>
+<h2>B) Installation on MS-Windows systems (XP, 2000 etc)</h2>
<pre>
- use either 'winGRASS with generic disply driver' (no Xserver needed) or 'winGRASS with XServer support'
- <a href=http://cran.at.r-project.org/>R for MS-Windows</a>
- - GRASS/R interface from Roger Bivand (there is one version running both
- under UN*X and MS-Windows)
+ - GRASS/R interface from Roger Bivand (it is running both under UN*X and MS-Windows)
Note: Installing R contribution packages requires that Perl 5.005 or later be
installed.
@@ -90,7 +89,7 @@
[Useful link? http://www.stats.ox.ac.uk/pub/Rtools/]
<hr>
-Once the GRASS/R interface reaches the standard contrib space on the R web
+Future: Once the GRASS/R interface reaches the standard contrib space on the R web
site, the options() command and install.packages() will work and simplify
the installation.
More information about the grass-web
