[GRASSweb-list]markus: web/statsgrass grass_r_insthints.html,1.3,1.4
grass at intevation.de
Thu Oct 31 10:28:33 EST 2002
Author: markus
Update of /grassrepository/web/statsgrass
In directory doto:/tmp/cvs-serv16126
Modified Files:
Log Message:
added url
Index: grass_r_insthints.html
RCS file: /grassrepository/web/statsgrass/grass_r_insthints.html,v
retrieving revision 1.3
retrieving revision 1.4
diff -u -d -r1.3 -r1.4
--- grass_r_insthints.html 31 Oct 2002 15:13:06 -0000 1.3
+++ grass_r_insthints.html 31 Oct 2002 15:28:31 -0000 1.4
@@ -64,12 +64,11 @@
<h2>B) Installation on MS-Windows systems (XP, 2000 etc)</h2>
<pre>
- - use either 'winGRASS with generic disply driver' (no Xserver needed) or 'winGRASS with XServer support'
+ - use either 'winGRASS with generic display driver' (no Xserver needed) or 'winGRASS with XServer support'
- <a href=http://cran.at.r-project.org/>R for MS-Windows</a>
- GRASS/R interface from Roger Bivand (it is running both under UN*X and MS-Windows)
-Note: Installing R contribution packages requires that Perl 5.005 or later be
-installed.
+ - Installing R contribution packages requires that <a href=http://www.cpan.org/ports/index.html#win32>Perl 5.005</a> or later be installed.
+ (e.g. <a href=http://downloads.activestate.com/ActivePerl/Windows/>ActivePerl</a>)
In general GRASS under Cygwin will connect to R for MS-Windows.
For the installation of R software please refer to the R web site.
More information about the grass-web
