[GRASSweb-list]markus: web/statsgrass grass_r_insthints.html,1.4,1.5
    grass at intevation.de
    Thu Oct 31 11:59:38 EST 2002
Author: markus
Update of /grassrepository/web/statsgrass
In directory doto:/tmp/cvs-serv17639
Modified Files:
Log Message:
final fix for today
Index: grass_r_insthints.html
RCS file: /grassrepository/web/statsgrass/grass_r_insthints.html,v
retrieving revision 1.4
retrieving revision 1.5
diff -u -d -r1.4 -r1.5
--- grass_r_insthints.html	31 Oct 2002 15:28:31 -0000	1.4
+++ grass_r_insthints.html	31 Oct 2002 16:59:36 -0000	1.5
@@ -65,13 +65,12 @@
 <pre>
  - use either 'winGRASS with generic display driver' (no Xserver needed) or 'winGRASS with XServer support'
- - <a href=http://cran.at.r-project.org/>R for MS-Windows</a>
+ - <a href=http://cran.at.r-project.org/>R for MS-Windows</a> - see <a href=http://www.biostat.jhsph.edu/~kbroman/Rintro/Rwinpack.html>install hints</a>
  - GRASS/R interface from Roger Bivand (it is running both under UN*X and MS-Windows)
  - Installing R contribution packages requires that <a href=http://www.cpan.org/ports/index.html#win32>Perl 5.005</a> or later be installed.
-   (e.g. <a href=http://downloads.activestate.com/ActivePerl/Windows/>ActivePerl</a>)
+   (e.g. <a href=http://www.activestate.com/Products/ActivePerl/Download.html>ActivePerl</a>)
-In general GRASS under Cygwin will connect to R for MS-Windows.
-For the installation of R software please refer to the R web site.
+In general winGRASS under Cygwin is able to talk to R/MS-Windows.
 Installation of the GRASS/R interface:
  - Instead of '/usr/bin/R' use 'Rcmd'
More information about the grass-web
