[GRASSweb-list]markus: web grasscvstags.html,1.25,1.26
    grass at intevation.de
    Tue Apr 15 04:52:16 EDT 2003
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv22310
Modified Files:
	grasscvstags.html
Log Message:
added CVSROOT instructions
Index: grasscvstags.html
RCS file: /grassrepository/web/grasscvstags.html,v
retrieving revision 1.25
retrieving revision 1.26
diff -u -d -r1.25 -r1.26
--- grasscvstags.html	11 Apr 2003 07:35:33 -0000	1.25
+++ grasscvstags.html	15 Apr 2003 08:52:14 -0000	1.26
@@ -19,8 +19,24 @@
 <h2>GRASS GIS CVS repository Tags and Branches</h2>
-Information about how to access our
-CVS repository you find <a href="grasscvs.html#access">here</a>.
+To set up your CVS client for read access simply set the environment
+variable <b>CVSROOT</b> to:
+<pre>    :pserver:grass-guest at intevation.de:/home/grass/grassrepository
+</pre>
+<small>
+(Consult your shell or cvs client on how to this. Example for unix bash:<br>
+<tt>
+ export CVSROOT=:pserver:grass-guest at intevation.de:/home/grass/grassrepository
+</tt>
+</small>
+<p>
+Then do a "cvs login" and type "grass" when your are asked for password.
+<P>
+More detailed information about how to access our
+CVS repository you find <a href="http://freegis.org//grass/grass-cvs.html">here</a>.
 <p>Tags in CVS indicate a development
 state, a moment in time. Here you find a list of GRASS releases tagged in
 CVS. If you want to download GRASS with defined status, you may use the "tags"
More information about the grass-web
