[GRASSweb-list]markus: web grasscvstags.html,1.25,1.26
Bernhard Reiter bernhard at intevation.de
Tue Apr 15 06:29:43 EDT 2003
Markus,
is it wise to dublicate the information?
We should keep http://freegis.org//grass/grass-cvs.html uptodate.
otherwise we have to correct this at several places when something
changes.
If there are changes to be made for grass-cvs.html, let me know.
	Bernhard
On Tue, Apr 15, 2003 at 10:52:16AM +0200, grass at intevation.de wrote:
> Update of /grassrepository/web
> In directory doto:/tmp/cvs-serv22310
> Modified Files:
> 	grasscvstags.html
> Log Message:
> added CVSROOT instructions
> Index: grasscvstags.html
> RCS file: /grassrepository/web/grasscvstags.html,v
> retrieving revision 1.25
> retrieving revision 1.26
> diff -u -d -r1.25 -r1.26
> --- grasscvstags.html	11 Apr 2003 07:35:33 -0000	1.25
> +++ grasscvstags.html	15 Apr 2003 08:52:14 -0000	1.26
> @@ -19,8 +19,24 @@
>  <h2>GRASS GIS CVS repository Tags and Branches</h2>
> -Information about how to access our
> -CVS repository you find <a href="grasscvs.html#access">here</a>.
> +To set up your CVS client for read access simply set the environment
> +variable <b>CVSROOT</b> to:
> +<pre>    :pserver:grass-guest at intevation.de:/home/grass/grassrepository
> +</pre>
> +<small>
> +(Consult your shell or cvs client on how to this. Example for unix bash:<br>
> +<tt>
> + export CVSROOT=:pserver:grass-guest at intevation.de:/home/grass/grassrepository
> +</tt>
> +</small>
> +<p>
> +Then do a "cvs login" and type "grass" when your are asked for password.
> +<P>
> +More detailed information about how to access our
> +CVS repository you find <a href="http://freegis.org//grass/grass-cvs.html">here</a>.
>  <p>Tags in CVS indicate a development
>  state, a moment in time. Here you find a list of GRASS releases tagged in
>  CVS. If you want to download GRASS with defined status, you may use the "tags"
> weblist mailing list
> weblist at grass.itc.it
> http://grass.itc.it/mailman/listinfo/weblist
Professional Service for Free Software                 (intevation.net)
The FreeGIS Project                                       (freegis.org)
Association for a Free Informational Infrastructure          (ffii.org)
FSF Europe                                              (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-web/attachments/20030415/ba229293/attachment.bin
More information about the grass-web mailing list
