[GRASSweb-list]questions about starting grass5
hcabria at nigs.upd.edu.ph
Fri Aug 1 01:24:13 EDT 2003
To the Grass Development Team
I am a new user of GRASS. I have just installed the GRASS 5 binary. I
have run the text mode part of GRASS and it went well. However when I
tried to switch to the Graphical interface mode I encountered a problem.
When I type $ grass5 -tcltk to start the program there is an error which
says that:
"WARNING: The wish command (wish) not found! Please check your GRASS_WISH
environment variable. Use the -help option for details." When I go to help
menu, it says that: GRASS_WISH set wish shell name to override 'wish'.
How do I do this? Where do I find the 'wish' shell? Please help me on
this.
Thank you.
Hillel
This email was sent using NIGS WebMail.
Powered by SquirrelMail - Webmail for nuts!
National Institute of Geological Sciences
http://www.nigs.upd.edu.ph/
More information about the grass-web
