[GRASSweb-list]questions about starting grass5
Bernhard Reiter
bernhard at intevation.de
Fri Aug 1 05:35:52 EDT 2003
Hello,
please ask questions like this on the GRASS user list.
This email list is about the webpages for GRASS.
It seems that you don't have tcl/tk installed.
Hope it helps,
Bernhard
On Fri, Aug 01, 2003 at 01:24:13PM +0800, hcabria at nigs.upd.edu.ph wrote:
> I am a new user of GRASS. I have just installed the GRASS 5 binary. I
> have run the text mode part of GRASS and it went well. However when I
> tried to switch to the Graphical interface mode I encountered a problem.
> When I type $ grass5 -tcltk to start the program there is an error which
> says that:
> "WARNING: The wish command (wish) not found! Please check your GRASS_WISH
> environment variable. Use the -help option for details." When I go to help
> menu, it says that: GRASS_WISH set wish shell name to override 'wish'.
> How do I do this? Where do I find the 'wish' shell? Please help me on
> this.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-web/attachments/20030801/e4de7643/attachment.bin
More information about the grass-web
