[GRASSweb-list]questions about starting grass5
Markus Neteler
neteler at itc.it
Fri Aug 1 05:36:24 EDT 2003
On Fri, Aug 01, 2003 at 01:24:13PM +0800, hcabria at nigs.upd.edu.ph wrote:
> To the Grass Development Team
> I am a new user of GRASS. I have just installed the GRASS 5 binary. I
> have run the text mode part of GRASS and it went well. However when I
> tried to switch to the Graphical interface mode I encountered a problem.
> When I type $ grass5 -tcltk to start the program there is an error which
> says that:
> "WARNING: The wish command (wish) not found! Please check your GRASS_WISH
> environment variable. Use the -help option for details." When I go to help
> menu, it says that: GRASS_WISH set wish shell name to override 'wish'.
> How do I do this? Where do I find the 'wish' shell? Please help me on
> this.
> Thank you.
Please have a look at the FAQ:
http://grass.itc.it/faq/
-> Installing GRASS
-> When using GRASS and the graphical user interface, I get tcltkgrass:
line3: exec: wish: not found
Markus Neteler <neteler at itc.it> http://mpa.itc.it
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
More information about the grass-web
