[GRASSweb-list]grass wiki header problems
Markus Neteler
neteler at itc.it
Tue Aug 26 04:15:37 EDT 2003
Richard,
the phpWIKI we are using is fairly poor and obviously
unmaintained. I have spent hours to get it working (again
and again as it tends to crash). At time it seems to
work.
On Sun, Aug 24, 2003 at 11:51:59AM -0400, Richard Murphy wrote:
> When I try to open a page in the GRASS WIKI, the page content is
> preceded and followed by several php error messages. These look like:
> lib/Request.php:220: Warning[2]: Cannot add header information -
> headers already sent by (output started at
> /var/www/phpwikicvs/index.php:2)
> This is probably very easy to fix; what it means is that something is
> being sent by the webserver to the browser before the php code starts.
> Check to make sure that the very first line of index.php is "<?php".
> If there is anything at all before this in the file, even a blank line
> or a space, it will cause this kind of error. If that doesn't fix it,
> I would be willing to look briefly at the code running the grass wiki
> and look for a solution.
I see - there was a blank first line in the index.php.
However, at time we have the favourite bug
lib/DbaDatabase.php:38: Fatal[256]: driver initialization failed
(try google to see how many phpWIKIs are crashed).
What I am looking for is
- install another Wiki (which implementation is stable? TWiki?)
- migrate the contents (needs volunteers)
- launch the new WIKI
- \rm -rf phpwiki
Best regards
Markus
Markus Neteler <neteler at itc.it> http://mpa.itc.it
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
More information about the grass-web
