[GRASSweb-list]grass wiki header problems
Markus Neteler neteler at itc.it
Tue Aug 26 04:18:46 EDT 2003
I have restarted Apache, now the Wiki is back and the warning
gone. Thanks for the hint, Richard.
Let's see how many days the wiki survives.
What I like most:
bash-2.04$ w
 10:18am  up 322 days, 20:44,  1 user,  load average: 0.01, 0.01, 0.00
Cheers
 Markus
On Tue, Aug 26, 2003 at 10:15:37AM +0200, Markus Neteler wrote:
> Richard,
> the phpWIKI we are using is fairly poor and obviously
> unmaintained. I have spent hours to get it working (again
> and again as it tends to crash). At time it seems to
> work.
> On Sun, Aug 24, 2003 at 11:51:59AM -0400, Richard Murphy wrote:
> > When I try to open a page in the GRASS WIKI, the page content is
> > preceded and followed by several php error messages.  These look like:
> > lib/Request.php:220: Warning[2]: Cannot add header information -
> > headers already sent by (output started at
> > /var/www/phpwikicvs/index.php:2)
> > This is probably very easy to fix; what it means is that something is
> > being sent by the webserver to the browser before the php code starts.
> > Check to make sure that the very first line of index.php is "<?php".
> > If there is anything at all before this in the file, even a blank line
> > or a space, it will cause this kind of error.  If that doesn't fix it,
> > I would be willing to look briefly at the code running the grass wiki
> > and look for a solution.
> I see - there was a blank first line in the index.php.
> However, at time we have the favourite bug
> lib/DbaDatabase.php:38: Fatal[256]: driver initialization failed
> (try google to see how many phpWIKIs are crashed).
> What I am looking for is
> - install another Wiki (which implementation is stable? TWiki?)
> - migrate the contents (needs volunteers)
> - launch the new WIKI
> - \rm -rf phpwiki
> Best regards
> Markus
> Markus Neteler     <neteler at itc.it>       http://mpa.itc.it
> ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
> weblist mailing list
> weblist at grass.itc.it
> http://grass.itc.it/mailman/listinfo/weblist
More information about the grass-web mailing list
