[GRASSweb-list]grass 5.0.3 doesn't find gd 2.0.8
Karel Kulhavý
clock at twibright.com
Wed Aug 18 16:27:53 EDT 2004
Hello
Sorry for forgetting attaching the typescript:
REQUIREMENTS.html of grass 5.0.3 says libgd preferrably 2.x series.
I have installed 2.0.8 libgd version and no other libgd version.
However grass 5.0.3 refuses to configure with a message that libgd
can't be found. I even tried specifying --with-gd-include.
typescript included where everything is shown including presence of
the required gd files on the system and their recentness.
CL<
Script started on Wed Aug 18 20:20:20 2004
clock at beton:~$ cd grass-5.0.3
clock at beton:~/grass-5.0.3$ ./configure --without-postgres --without-odbc --with-
freetype
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking whether the C compiler (gcc -O2 -march=athlon-xp -fomit-frame-pointer -fstrength-reduce -fschedule-insns -I/home/clock/usr/include -L/home/clock/usr/lib) works... yes
checking whether the C compiler (gcc -O2 -march=athlon-xp -fomit-frame-pointer -fstrength-reduce -fschedule-insns -I/home/clock/usr/include -L/home/clock/usr/lib) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for full floating-point support... yes
checking for pwd... /bin/pwd
checking for source directory... /home/clock/grass-5.0.3
checking for build directory... /home/clock/grass-5.0.3
checking for SysV... no
checking for another button... no
checking for XDriver... socket
checking for additional include dirs...
checking for additional library dirs...
checking for a BSD compatible install... /bin/install -c
checking for flex... flex
checking for yywrap in -lfl... yes
checking for bison... bison -y
checking for ranlib... ranlib
checking for ar... ar
checking for env... env
checking for g77... g77
checking for perl... /usr/bin/perl
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for curses.h... yes
checking for limits.h... yes
checking for termio.h... yes
checking for termios.h... yes
checking for unistd.h... yes
checking for values.h... yes
checking for g2c.h... yes
checking for f2c.h... no
checking for sys/ioctl.h... yes
checking for sys/mtio.h... yes
checking for sys/resource.h... yes
checking for sys/time.h... yes
checking for sys/timeb.h... yes
checking for sys/types.h... yes
checking for sys/utsname.h... yes
checking for libintl.h... yes
checking for iconv.h... yes
checking whether time.h and sys/time.h may both be included... yes
checking for off_t... yes
checking for uid_t in sys/types.h... yes
checking return type of signal handlers... void
checking for Cygwin environment... no
checking for ftime... yes
checking for gethostname... yes
checking for gettimeofday... yes
checking for lseek... yes
checking for nice... yes
checking for time... yes
checking for uname... yes
checking for seteuid... yes
checking for setpriority... yes
checking for setreuid... yes
checking for setruid... no
checking for drand48... yes
checking whether setpgrp takes no argument... yes
checking for W11... no
checking for X... libraries /usr/X11R6/lib, headers /usr/X11R6/include
checking for dnet_ntoa in -ldnet... no
checking for dnet_ntoa in -ldnet_stub... no
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking curses.h WINDOW structure component... _maxy
checking for initscr in -lncurses... yes
checking for keypad in -lncurses... yes
checking for gtty in -lcompat... no
checking for gtty in -lbsd-compat... yes
checking for xdrmem_create... yes
checking for atan... no
checking for atan in -lm... yes
checking for dlsym... no
checking for dlsym in -ldl... yes
checking for iconv... yes
checking for gettext... yes
checking for socket... yes
checking for location of zlib includes...
checking for zlib.h... yes
checking for location of zlib library...
checking for deflate in -lz... yes
checking whether to use DBM... no
checking whether to use Readline... no
checking whether to use JPEG... yes
checking for location of JPEG includes...
checking for jpeglib.h... yes
checking for location of JPEG library...
checking for jpeg_start_compress in -ljpeg... yes
checking if we should build directly against GDAL... no
checking whether to use TIFF... yes
checking for location of TIFF includes...
checking for tiffio.h... yes
checking for TIFFOpen in -ltiff... yes
checking whether to use PNG... yes
checking for location of PNG includes...
checking for png.h... yes
checking for location of PNG library...
checking for png_read_image in -lpng... yes
checking whether to use GD... yes
checking for location of GD includes...
checking for gd.h... yes
checking for location of GD library...
checking for gdImagePng in -lgd... no
checking for gdImageGif in -lgd... no
configure: error: *** Unable to locate GD library.
clock at beton:~/grass-5.0.3$ locate libg.
/usr/lib/libg.a
clock at beton:~/grass-5.0.3$ locate libg. d
/usr/bin/libgdgeda-config
/usr/lib/libgdal.a
/usr/lib/libgdal.la
/usr/lib/libgdal.so
/usr/lib/libgdal.so.1
/usr/lib/libgdal.so.1.3.0
/usr/lib/libgdbm.a
/usr/lib/libgdbm.la
/usr/lib/libgdbm.so
/usr/lib/libgdbm.so.3
/usr/lib/libgdbm.so.3.0.0
/usr/lib/libgdgeda.a
/usr/lib/libgdgeda.la
/usr/lib/libgdgeda.so
/usr/lib/libgdgeda.so.4
/usr/lib/libgdgeda.so.4.0.0
/usr/lib/libgdgeda.so.5
/usr/lib/libgdgeda.so.5.0.0
/usr/lib/libgdgeda.so.6
/usr/lib/libgdgeda.so.6.0.0
/usr/lib/libgdk-1.2.so.0
/usr/lib/libgdk-1.2.so.0.9.0
/usr/lib/libgdk-1.2.so.0.9.1
/usr/lib/libgdk-x11-2.0.la
/usr/lib/libgdk-x11-2.0.so
/usr/lib/libgdk-x11-2.0.so.0
/usr/lib/libgdk-x11-2.0.so.0.0.9
/usr/lib/libgdk-x11-2.0.so.0.200.1
/usr/lib/libgdk-x11-2.0.so.0.400.0
/usr/lib/libgdk-x11-2.0.so.0.400.1
/usr/lib/libgdk.a
/usr/lib/libgdk.la
/usr/lib/libgdk.so
/usr/lib/libgdkmm-1.2.so.1
/usr/lib/libgdkmm-1.2.so.1.1.2
/usr/lib/libgdkmm.la
/usr/lib/libgdkmm.so
/usr/lib/libgdk_imlib.a
/usr/lib/libgdk_imlib.la
/usr/lib/libgdk_imlib.so
/usr/lib/libgdk_imlib.so.1
/usr/lib/libgdk_imlib.so.1.9.14
/usr/lib/libgdk_pixbuf-2.0.la
/usr/lib/libgdk_pixbuf-2.0.so
/usr/lib/libgdk_pixbuf-2.0.so.0
/usr/lib/libgdk_pixbuf-2.0.so.0.0.9
/usr/lib/libgdk_pixbuf-2.0.so.0.200.1
/usr/lib/libgdk_pixbuf-2.0.so.0.400.0
/usr/lib/libgdk_pixbuf-2.0.so.0.400.1
/usr/lib/libgdk_pixbuf.a
/usr/lib/libgdk_pixbuf.la
/usr/lib/libgdk_pixbuf.so
/usr/lib/libgdk_pixbuf.so.2
/usr/lib/libgdk_pixbuf.so.2.0.0
/usr/lib/libgdk_pixbuf_xlib-2.0.la
/usr/lib/libgdk_pixbuf_xlib-2.0.so
/usr/lib/libgdk_pixbuf_xlib-2.0.so.0
/usr/lib/libgdk_pixbuf_xlib-2.0.so.0.0.9
/usr/lib/libgdk_pixbuf_xlib-2.0.so.0.200.1
/usr/lib/libgdk_pixbuf_xlib-2.0.so.0.400.0
/usr/lib/libgdk_pixbuf_xlib-2.0.so.0.400.1
/usr/lib/libgdk_pixbuf_xlib.a
/usr/lib/libgdk_pixbuf_xlib.la
/usr/lib/libgdk_pixbuf_xlib.so
/usr/lib/libgdk_pixbuf_xlib.so.2
/usr/lib/libgdk_pixbuf_xlib.so.2.0.0
/usr/lib/pkgconfig/imlibgdk.pc
/usr/lib/pkgconfig/libgdgeda.pc
/usr/local/lib/libgd.a
/usr/local/lib/libgd.la
/usr/local/lib/libgd.so
/usr/local/lib/libgd.so.2
/usr/local/lib/libgd.so.2.0.0
/usr/src/gaf/libgdgeda-2.0.15
/usr/src/gaf/libgdgeda-2.0.15.tar.gz
/usr/src/gaf/libgdgeda-2.0.15/.deps
/usr/src/gaf/libgdgeda-2.0.15/.deps/annotate.Po
/usr/src/gaf/libgdgeda-2.0.15/.deps/fontsizetest.Po
/usr/src/gaf/libgdgeda-2.0.15/.deps/fontwheeltest.Po
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd2copypal.Po
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd2time.Po
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd2topng.Po
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdcache.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gddemo.Po
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdfontg.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdfontl.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdfontmb.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdfonts.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdfontt.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdft.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdhelpers.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdkanji.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdparttopng.Po
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdtables.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdtest.Po
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdtestft.Po
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdtopng.Po
/usr/src/gaf/libgdgeda-2.0.15/.deps/gdxpm.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd_gd.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd_gd2.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd_io.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd_io_dp.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd_io_file.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd_io_ss.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd_jpeg.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd_png.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd_ss.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd_topal.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/gd_wbmp.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/pngtogd.Po
/usr/src/gaf/libgdgeda-2.0.15/.deps/pngtogd2.Po
/usr/src/gaf/libgdgeda-2.0.15/.deps/testac.Po
/usr/src/gaf/libgdgeda-2.0.15/.deps/wbmp.Plo
/usr/src/gaf/libgdgeda-2.0.15/.deps/webpng.Po
/usr/src/gaf/libgdgeda-2.0.15/.libs
/usr/src/gaf/libgdgeda-2.0.15/.libs/annotate
/usr/src/gaf/libgdgeda-2.0.15/.libs/fontsizetest
/usr/src/gaf/libgdgeda-2.0.15/.libs/fontwheeltest
/usr/src/gaf/libgdgeda-2.0.15/.libs/gd2copypal
/usr/src/gaf/libgdgeda-2.0.15/.libs/gd2time
/usr/src/gaf/libgdgeda-2.0.15/.libs/gd2topng
/usr/src/gaf/libgdgeda-2.0.15/.libs/gddemo
/usr/src/gaf/libgdgeda-2.0.15/.libs/gdparttopng
/usr/src/gaf/libgdgeda-2.0.15/.libs/gdtest
/usr/src/gaf/libgdgeda-2.0.15/.libs/gdtestft
/usr/src/gaf/libgdgeda-2.0.15/.libs/gdtopng
/usr/src/gaf/libgdgeda-2.0.15/.libs/libgdgeda.a
/usr/src/gaf/libgdgeda-2.0.15/.libs/libgdgeda.la
/usr/src/gaf/libgdgeda-2.0.15/.libs/libgdgeda.lai
/usr/src/gaf/libgdgeda-2.0.15/.libs/libgdgeda.so
/usr/src/gaf/libgdgeda-2.0.15/.libs/libgdgeda.so.6
/usr/src/gaf/libgdgeda-2.0.15/.libs/libgdgeda.so.6.0.0
/usr/src/gaf/libgdgeda-2.0.15/.libs/pngtogd
/usr/src/gaf/libgdgeda-2.0.15/.libs/pngtogd2
/usr/src/gaf/libgdgeda-2.0.15/.libs/testac
/usr/src/gaf/libgdgeda-2.0.15/.libs/webpng
/usr/src/gaf/libgdgeda-2.0.15/aclocal.m4
/usr/src/gaf/libgdgeda-2.0.15/annotate
/usr/src/gaf/libgdgeda-2.0.15/annotate.c
/usr/src/gaf/libgdgeda-2.0.15/annotate.o
/usr/src/gaf/libgdgeda-2.0.15/bdftogd
/usr/src/gaf/libgdgeda-2.0.15/config
/usr/src/gaf/libgdgeda-2.0.15/config.h
/usr/src/gaf/libgdgeda-2.0.15/config.hin
/usr/src/gaf/libgdgeda-2.0.15/config.log
/usr/src/gaf/libgdgeda-2.0.15/config.status
/usr/src/gaf/libgdgeda-2.0.15/config/config.guess
/usr/src/gaf/libgdgeda-2.0.15/config/config.rpath
/usr/src/gaf/libgdgeda-2.0.15/config/config.sub
/usr/src/gaf/libgdgeda-2.0.15/config/depcomp
/usr/src/gaf/libgdgeda-2.0.15/config/install-sh
/usr/src/gaf/libgdgeda-2.0.15/config/libgdgeda-config
/usr/src/gaf/libgdgeda-2.0.15/config/libgdgeda-config.in
/usr/src/gaf/libgdgeda-2.0.15/config/libgdgeda.pc
/usr/src/gaf/libgdgeda-2.0.15/config/libgdgeda.pc.in
/usr/src/gaf/libgdgeda-2.0.15/config/ltmain.sh
/usr/src/gaf/libgdgeda-2.0.15/config/Makefile
/usr/src/gaf/libgdgeda-2.0.15/config/Makefile.am
/usr/src/gaf/libgdgeda-2.0.15/config/Makefile.in
/usr/src/gaf/libgdgeda-2.0.15/config/missing
/usr/src/gaf/libgdgeda-2.0.15/config/mkinstalldirs
/usr/src/gaf/libgdgeda-2.0.15/configure
/usr/src/gaf/libgdgeda-2.0.15/configure.ac
/usr/src/gaf/libgdgeda-2.0.15/configure.pl
/usr/src/gaf/libgdgeda-2.0.15/COPYING
/usr/src/gaf/libgdgeda-2.0.15/demoin.png
/usr/src/gaf/libgdgeda-2.0.15/depcomp
/usr/src/gaf/libgdgeda-2.0.15/err.out
/usr/src/gaf/libgdgeda-2.0.15/fontsizetest
/usr/src/gaf/libgdgeda-2.0.15/fontsizetest.c
/usr/src/gaf/libgdgeda-2.0.15/fontsizetest.o
/usr/src/gaf/libgdgeda-2.0.15/fontwheeltest
/usr/src/gaf/libgdgeda-2.0.15/fontwheeltest.c
/usr/src/gaf/libgdgeda-2.0.15/fontwheeltest.o
/usr/src/gaf/libgdgeda-2.0.15/gd.c
/usr/src/gaf/libgdgeda-2.0.15/gd.h
/usr/src/gaf/libgdgeda-2.0.15/gd.lo
/usr/src/gaf/libgdgeda-2.0.15/gd.o
/usr/src/gaf/libgdgeda-2.0.15/gd2copypal
/usr/src/gaf/libgdgeda-2.0.15/gd2copypal.c
/usr/src/gaf/libgdgeda-2.0.15/gd2copypal.o
/usr/src/gaf/libgdgeda-2.0.15/gd2time
/usr/src/gaf/libgdgeda-2.0.15/gd2time.c
/usr/src/gaf/libgdgeda-2.0.15/gd2time.o
/usr/src/gaf/libgdgeda-2.0.15/gd2topng
/usr/src/gaf/libgdgeda-2.0.15/gd2topng.c
/usr/src/gaf/libgdgeda-2.0.15/gd2topng.o
/usr/src/gaf/libgdgeda-2.0.15/gdcache.c
/usr/src/gaf/libgdgeda-2.0.15/gdcache.h
/usr/src/gaf/libgdgeda-2.0.15/gdcache.lo
/usr/src/gaf/libgdgeda-2.0.15/gdcache.o
/usr/src/gaf/libgdgeda-2.0.15/gddemo
/usr/src/gaf/libgdgeda-2.0.15/gddemo.c
/usr/src/gaf/libgdgeda-2.0.15/gddemo.o
/usr/src/gaf/libgdgeda-2.0.15/gdfontg.c
/usr/src/gaf/libgdgeda-2.0.15/gdfontg.h
/usr/src/gaf/libgdgeda-2.0.15/gdfontg.lo
/usr/src/gaf/libgdgeda-2.0.15/gdfontg.o
/usr/src/gaf/libgdgeda-2.0.15/gdfontl.c
/usr/src/gaf/libgdgeda-2.0.15/gdfontl.h
/usr/src/gaf/libgdgeda-2.0.15/gdfontl.lo
/usr/src/gaf/libgdgeda-2.0.15/gdfontl.o
/usr/src/gaf/libgdgeda-2.0.15/gdfontmb.c
/usr/src/gaf/libgdgeda-2.0.15/gdfontmb.h
/usr/src/gaf/libgdgeda-2.0.15/gdfontmb.lo
/usr/src/gaf/libgdgeda-2.0.15/gdfontmb.o
/usr/src/gaf/libgdgeda-2.0.15/gdfonts.c
/usr/src/gaf/libgdgeda-2.0.15/gdfonts.h
/usr/src/gaf/libgdgeda-2.0.15/gdfonts.lo
/usr/src/gaf/libgdgeda-2.0.15/gdfonts.o
/usr/src/gaf/libgdgeda-2.0.15/gdfontt.c
/usr/src/gaf/libgdgeda-2.0.15/gdfontt.h
/usr/src/gaf/libgdgeda-2.0.15/gdfontt.lo
/usr/src/gaf/libgdgeda-2.0.15/gdfontt.o
/usr/src/gaf/libgdgeda-2.0.15/gdft.c
/usr/src/gaf/libgdgeda-2.0.15/gdft.lo
/usr/src/gaf/libgdgeda-2.0.15/gdft.o
/usr/src/gaf/libgdgeda-2.0.15/gdhelpers.c
/usr/src/gaf/libgdgeda-2.0.15/gdhelpers.h
/usr/src/gaf/libgdgeda-2.0.15/gdhelpers.lo
/usr/src/gaf/libgdgeda-2.0.15/gdhelpers.o
/usr/src/gaf/libgdgeda-2.0.15/gdkanji.c
/usr/src/gaf/libgdgeda-2.0.15/gdkanji.lo
/usr/src/gaf/libgdgeda-2.0.15/gdkanji.o
/usr/src/gaf/libgdgeda-2.0.15/gdparttopng
/usr/src/gaf/libgdgeda-2.0.15/gdparttopng.c
/usr/src/gaf/libgdgeda-2.0.15/gdparttopng.o
/usr/src/gaf/libgdgeda-2.0.15/gdtables.c
/usr/src/gaf/libgdgeda-2.0.15/gdtables.c.orig
/usr/src/gaf/libgdgeda-2.0.15/gdtables.lo
/usr/src/gaf/libgdgeda-2.0.15/gdtables.o
/usr/src/gaf/libgdgeda-2.0.15/gdtest
/usr/src/gaf/libgdgeda-2.0.15/gdtest.c
/usr/src/gaf/libgdgeda-2.0.15/gdtest.o
/usr/src/gaf/libgdgeda-2.0.15/gdtestft
/usr/src/gaf/libgdgeda-2.0.15/gdtestft.c
/usr/src/gaf/libgdgeda-2.0.15/gdtestft.o
/usr/src/gaf/libgdgeda-2.0.15/gdtopng
/usr/src/gaf/libgdgeda-2.0.15/gdtopng.c
/usr/src/gaf/libgdgeda-2.0.15/gdtopng.o
/usr/src/gaf/libgdgeda-2.0.15/gdxpm.c
/usr/src/gaf/libgdgeda-2.0.15/gdxpm.lo
/usr/src/gaf/libgdgeda-2.0.15/gdxpm.o
/usr/src/gaf/libgdgeda-2.0.15/gd_gd.c
/usr/src/gaf/libgdgeda-2.0.15/gd_gd.lo
/usr/src/gaf/libgdgeda-2.0.15/gd_gd.o
/usr/src/gaf/libgdgeda-2.0.15/gd_gd2.c
/usr/src/gaf/libgdgeda-2.0.15/gd_gd2.lo
/usr/src/gaf/libgdgeda-2.0.15/gd_gd2.o
/usr/src/gaf/libgdgeda-2.0.15/gd_io.c
/usr/src/gaf/libgdgeda-2.0.15/gd_io.h
/usr/src/gaf/libgdgeda-2.0.15/gd_io.lo
/usr/src/gaf/libgdgeda-2.0.15/gd_io.o
/usr/src/gaf/libgdgeda-2.0.15/gd_io_dp.c
/usr/src/gaf/libgdgeda-2.0.15/gd_io_dp.lo
/usr/src/gaf/libgdgeda-2.0.15/gd_io_dp.o
/usr/src/gaf/libgdgeda-2.0.15/gd_io_file.c
/usr/src/gaf/libgdgeda-2.0.15/gd_io_file.lo
/usr/src/gaf/libgdgeda-2.0.15/gd_io_file.o
/usr/src/gaf/libgdgeda-2.0.15/gd_io_ss.c
/usr/src/gaf/libgdgeda-2.0.15/gd_io_ss.lo
/usr/src/gaf/libgdgeda-2.0.15/gd_io_ss.o
/usr/src/gaf/libgdgeda-2.0.15/gd_jpeg.c
/usr/src/gaf/libgdgeda-2.0.15/gd_jpeg.lo
/usr/src/gaf/libgdgeda-2.0.15/gd_jpeg.o
/usr/src/gaf/libgdgeda-2.0.15/gd_png.c
/usr/src/gaf/libgdgeda-2.0.15/gd_png.lo
/usr/src/gaf/libgdgeda-2.0.15/gd_png.o
/usr/src/gaf/libgdgeda-2.0.15/gd_ss.c
/usr/src/gaf/libgdgeda-2.0.15/gd_ss.lo
/usr/src/gaf/libgdgeda-2.0.15/gd_ss.o
/usr/src/gaf/libgdgeda-2.0.15/gd_topal.c
/usr/src/gaf/libgdgeda-2.0.15/gd_topal.lo
/usr/src/gaf/libgdgeda-2.0.15/gd_topal.o
/usr/src/gaf/libgdgeda-2.0.15/gd_wbmp.c
/usr/src/gaf/libgdgeda-2.0.15/gd_wbmp.lo
/usr/src/gaf/libgdgeda-2.0.15/gd_wbmp.o
/usr/src/gaf/libgdgeda-2.0.15/index.html
/usr/src/gaf/libgdgeda-2.0.15/INSTALL
/usr/src/gaf/libgdgeda-2.0.15/install-item
/usr/src/gaf/libgdgeda-2.0.15/install-sh
/usr/src/gaf/libgdgeda-2.0.15/jisx0208.h
/usr/src/gaf/libgdgeda-2.0.15/libgdgeda.la
/usr/src/gaf/libgdgeda-2.0.15/libtool
/usr/src/gaf/libgdgeda-2.0.15/Makefile
/usr/src/gaf/libgdgeda-2.0.15/Makefile.am
/usr/src/gaf/libgdgeda-2.0.15/Makefile.in
/usr/src/gaf/libgdgeda-2.0.15/makefile.sample
/usr/src/gaf/libgdgeda-2.0.15/missing
/usr/src/gaf/libgdgeda-2.0.15/mkinstalldirs
/usr/src/gaf/libgdgeda-2.0.15/pngtogd
/usr/src/gaf/libgdgeda-2.0.15/pngtogd.c
/usr/src/gaf/libgdgeda-2.0.15/pngtogd.o
/usr/src/gaf/libgdgeda-2.0.15/pngtogd2
/usr/src/gaf/libgdgeda-2.0.15/pngtogd2.c
/usr/src/gaf/libgdgeda-2.0.15/pngtogd2.o
/usr/src/gaf/libgdgeda-2.0.15/README-JPEG.TXT
/usr/src/gaf/libgdgeda-2.0.15/README.1ST
/usr/src/gaf/libgdgeda-2.0.15/readme.jpn
/usr/src/gaf/libgdgeda-2.0.15/README.TXT
/usr/src/gaf/libgdgeda-2.0.15/stamp-h1
/usr/src/gaf/libgdgeda-2.0.15/test
/usr/src/gaf/libgdgeda-2.0.15/test/gdtest.gd2
/usr/src/gaf/libgdgeda-2.0.15/test/gdtest.png
/usr/src/gaf/libgdgeda-2.0.15/test/gdtest_200_300_150_100.png
/usr/src/gaf/libgdgeda-2.0.15/test/gdtest_merge.png
/usr/src/gaf/libgdgeda-2.0.15/test/gdtest_wbmp_to_png.png
/usr/src/gaf/libgdgeda-2.0.15/test/Makefile
/usr/src/gaf/libgdgeda-2.0.15/test/Makefile.am
/usr/src/gaf/libgdgeda-2.0.15/test/Makefile.in
/usr/src/gaf/libgdgeda-2.0.15/testac
/usr/src/gaf/libgdgeda-2.0.15/testac.c
/usr/src/gaf/libgdgeda-2.0.15/testac.o
/usr/src/gaf/libgdgeda-2.0.15/wbmp.c
/usr/src/gaf/libgdgeda-2.0.15/wbmp.h
/usr/src/gaf/libgdgeda-2.0.15/wbmp.lo
/usr/src/gaf/libgdgeda-2.0.15/wbmp.o
/usr/src/gaf/libgdgeda-2.0.15/webpng
/usr/src/gaf/libgdgeda-2.0.15/webpng.c
/usr/src/gaf/libgdgeda-2.0.15/webpng.o
clock at beton:~/grass-5.0.3$ locate libgd.
clock at beton:~/grass-5.0.3$ ls -la `locate libgd.`
-rw-r--r-- 1 root root 259636 Aug 18 19:46 /usr/local/lib/libgd.a
-rwxr-xr-x 1 root root 832 Aug 18 19:46 /usr/local/lib/libgd.la
lrwxrwxrwx 1 root root 14 Aug 18 19:46 /usr/local/lib/libgd.so -> libgd.so.2.0.0
lrwxrwxrwx 1 root root 14 Aug 18 19:46 /usr/local/lib/libgd.so.2 -> libgd.so.2.0.0
-rwxr-xr-x 1 root root 294434 Aug 18 19:46 /usr/local/lib/libgd.so.2.0.0
clock at beton:~/grass-5.0.3$ locate gd.h
/usr/include/gdgeda/gd.h
/usr/local/include/gd.h
clock at beton:~/grass-5.0.3$ ls -la /usr/local/include/gd.h
-rw-r--r-- 1 root root 29067 Aug 18 19:46 /usr/local/include/gd.h
clock at beton:~/grass-5.0.3$ ls -la /usr/local/include/gd.h[19Pocate gd.hs -la `locate libgd.`[9Pocate libgd.[K../configure --without-postgres --without-odbc --with-f
freetype --with-gd-includes=/usr/local/include
checking for location of GD includes... /usr/local/include
clock at beton:~/grass-5.0.3$ exit
Script done on Wed Aug 18 20:21:34 2004
More information about the grass-web
