[GRASSweb-list]bernhard: web/grass51/tutorial ex_basic.html,1.14,1.15
    grass at intevation.de
    Thu Feb 26 11:05:14 EST 2004
Author: bernhard
Update of /grassrepository/web/grass51/tutorial
In directory doto:/tmp/cvs-serv21427
Modified Files:
	ex_basic.html
Log Message:
Claried dangers of v.in.dwg and a hint how to remedy the situation.
Index: ex_basic.html
RCS file: /grassrepository/web/grass51/tutorial/ex_basic.html,v
retrieving revision 1.14
retrieving revision 1.15
diff -u -d -r1.14 -r1.15
--- ex_basic.html	25 Feb 2004 23:47:54 -0000	1.14
+++ ex_basic.html	26 Feb 2004 16:05:12 -0000	1.15
@@ -114,10 +114,16 @@
 <DIV ALIGN=right><a href="#toc">[UP]</a></DIV>
 </b></big></font></td></tr></table>
-<i>NOTE:  v.in.dwg requires OpenDWG toolkit. To get this toolkit
+<strong>WARNING:  v.in.dwg requires OpenDWG toolkit,
+which is proprietary software!
+To get this toolkit
 you must become at least "Associate Member" of OpenDWG Alliance
 (http://www.opendwg.org), it is free-of-charge (you have to fill one form).
-</i>
+If you distribute GRASS binaries with linked OpenDWG, you are violating
+the license of GRASS.
+Please help us to create a better DWG library
+or to convince the OpenDWG Allicance to change the license.
+</strong>
 [for this exercise we use the Spearfish data set from the GRASS web site]<br>
 [The WATRTOWR.DXF can be found <a href=http://www.3dcafe.com/asp/architex.asp#DXF>here</a>]
 <P>
More information about the grass-web
