[GRASSweb-list]markus: web/grass51/tutorial geom_storage.html,1.22,1.23
grass at intevation.de
Wed Jan 21 06:07:02 EST 2004
Author: markus
Update of /grassrepository/web/grass51/tutorial
In directory doto:/tmp/cvs-serv32620
Modified Files:
geom_storage.html
Log Message:
v.convert -> v.in.ogr
Index: geom_storage.html
RCS file: /grassrepository/web/grass51/tutorial/geom_storage.html,v
retrieving revision 1.22
retrieving revision 1.23
diff -u -d -r1.22 -r1.23
--- geom_storage.html 10 Nov 2003 17:27:15 -0000 1.22
+++ geom_storage.html 21 Jan 2004 11:07:00 -0000 1.23
@@ -222,7 +222,7 @@
We are ready to import the data now which will be stored directly in our PostGRASS server:
<div class="code"><pre>
-v.convert input=census1990wet.shp output=census1990wet
+v.in.ogr dsn=census1990wet.shp output=census1990wet
v.info census1990wet
Map format: postgis
More information about the grass-web
