[GRASSweb-list]markus: web grasscvstags.html,1.30,1.31
grass at intevation.de grass at intevation.de
Mon Jun 21 05:49:38 EDT 2004
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv27398
Modified Files:
	grasscvstags.html
Log Message:
5.7.0 tag added
Index: grasscvstags.html
RCS file: /grassrepository/web/grasscvstags.html,v
retrieving revision 1.30
retrieving revision 1.31
diff -u -d -r1.30 -r1.31
--- grasscvstags.html	11 Mar 2004 16:29:50 -0000	1.30
+++ grasscvstags.html	21 Jun 2004 09:49:36 -0000	1.31
@@ -42,7 +42,7 @@
 CVS. If you want to download GRASS with defined status, you may use the "tags"
 denoted here: </p>
-<h2>GRASS 5.0.x stable branch:</h2>
+<h2>GRASS 5.0.x stable branch (old):</h2>
 <ul>
 <li>To check out the <b>stable</b> branch, enter:<p>
@@ -53,14 +53,6 @@
   <tt>cvs -z3 update -dP -r releasebranch_26_april_2002_5_0_0</tt>
 </ul>
-<h2>GRASS 5.3.x Experimental (HEAD):</h2>
-<ul>
-<li>To check out the lastest <b>unstable</b> 5.3.x code into a fresh directory,
-    enter:<p>
-    <tt>cvs -z3 checkout grass</tt>
-</ul>
 <h2>CVS Tags in GRASS 5.0.x</h2>
@@ -102,6 +94,18 @@
  </ul>
 <hr>
+<h2>GRASS 5.3.x Experimental (HEAD):</h2>
+Work is done here as well as in 5.7.
+<ul>
+<li>To check out the lastest <b>unstable</b> 5.3.x code into a fresh directory,
+    enter:<p>
+    <tt>cvs -z3 checkout grass</tt>
+</ul>
+<hr>
 <h2>GRASS 5.7 Experimental: CVS tags</h2>
 <ul>
@@ -110,13 +114,17 @@
     <tt>cvs -z3 checkout grass51</tt>
 <p>
 Note that you also need the latest <b>unstable</b> 5.3.x code to compile 5.7.x.
+</ul>
-</ul>
+<h3>GRASS 5.7.0 release tags</a>
+ <ul>
+   <li>GRASS 5.7.0: has been tagged as "release_17_06_2004_grass5_7_0"</li>
+ </ul>
 <!-- FOOTER -->
 <hr>
-<DIV ALIGN=right>&copy; 2000-2003 GRASS Development Team<br>
+<DIV ALIGN=right>&copy; 2000-2004 GRASS Development Team<br>
 <a href="mailto:weblist at grass.itc.it">Comments</a> about this page | <a href="faq/index.html">FAQ</a> | <a href="download.html">Download</a> | <a href="support.html">Support</a> | <a href="gdp/index.html">Docs</a>  | <a href="grassdevel.html">Programming</a> | Back <a href=index.html>HOME</a><br>
 <i>Last change:
 $Date$
More information about the grass-web mailing list
