[GRASSweb-list]markus: web/faq gtopo30_import.html,1.2,1.3
grass at intevation.de
Mon Jun 21 08:18:11 EDT 2004
Author: markus
Update of /grassrepository/web/faq
In directory doto:/tmp/cvs-serv29309
Modified Files:
gtopo30_import.html
Log Message:
fixed GTOPO30 import
Index: gtopo30_import.html
RCS file: /grassrepository/web/faq/gtopo30_import.html,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- gtopo30_import.html 30 Oct 2002 11:14:16 -0000 1.2
+++ gtopo30_import.html 21 Jun 2004 12:18:09 -0000 1.3
@@ -106,13 +106,10 @@
Ex:
-r.in.bin -s input=E020N90.DEM output=gtopo30 bytes=2 north=90 south=40
+r.in.bin -bs input=E020N90.DEM output=gtopo30 bytes=2 north=90 south=40
east=60 west=20 r=6000 c=4800
-(you can add "subst=-9999,0" if you want sea level to have 0 value)
-Using GRASS 5 you can replace the -9999 value with NULL (no data):
- r.null map=gtopo30 setnull=-9999
+(you can add "anull=-9999" if you want sea level to have No data value)
</pre>
9. Look at the data or calculate something...
@@ -121,7 +118,7 @@
<HR>
<A HREF="index.html">Go back to GRASS GIS FAQ...</A>
<HR>
-<em>Last Modified: 25. Feb. 2000</em>
+<em>Last Modified: 21 June 2004</em>
<address>
<A HREF="mailto:bouchard at onera.fr">Jacques Bouchard</A> / <A HREF="mailto:weblist at grass.itc.it">Markus Neteler</A>
</address>
More information about the grass-web
