[GRASSweb-list]markus: web/grass57/binary/mswindows_cygwin README.html,1.2,1.3 download.html,1.5,NONE
grass at intevation.de grass at intevation.de
Thu Jun 24 11:42:36 EDT 2004
Author: markus
Update of /grassrepository/web/grass57/binary/mswindows_cygwin
In directory doto:/tmp/cvs-serv24602
Modified Files:
	README.html
Removed Files:
	download.html
Log Message:
updated
Index: README.html
RCS file: /grassrepository/web/grass57/binary/mswindows_cygwin/README.html,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- README.html	29 Mar 2004 16:44:34 -0000	1.2
+++ README.html	24 Jun 2004 15:42:33 -0000	1.3
@@ -2,7 +2,7 @@
 <HTML> <BODY BGCOLOR=#FFFFFF>
 <pre>
 This directory contains the MS-Windows/Cygwin binary code for
-GRASS 5.7.x EXPERIMENTAL in gzipped tar format (or a link where to <a href=download.html>download</a>).
+GRASS 5.7.x in gzipped tar format).
 <b>Note that this binary version may not work.
    Use at your own risk.</b>
@@ -10,15 +10,14 @@
 Installation:
 1. get the file
-     grass57-DD-MM-YYYY-arch-bin.tar.gz
+     grass-5.7.0-DD-MM-YYYY-arch-bin.tar.gz
 2. get the installation script
-     grass57-DD-MM-YYYY-arch-install.sh
+     grass-5.7.0-DD-MM-YYYY-arch-install.sh
-Note: this code is highly experimental and may be malfunctioning.<br>
 For installation, run the install script with --help option:
-     grass57-DD-MM-YYYY-arch-install.sh --help
+     grass-5.7.0-DD-MM-YYYY-arch-install.sh --help
 <hr>
--- download.html DELETED ---
More information about the grass-web mailing list
