[GRASSweb-list]markus: web/grass57/binary/linux/snapshot README.html,1.1,1.2
grass at intevation.de
Fri Jun 25 05:02:00 EDT 2004
Author: markus
Update of /grassrepository/web/grass57/binary/linux/snapshot
In directory doto:/tmp/cvs-serv5050
Modified Files:
README.html
Log Message:
updated by Paolo Cavallini
Index: README.html
RCS file: /grassrepository/web/grass57/binary/linux/snapshot/README.html,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- README.html 17 Jun 2004 15:40:17 -0000 1.1
+++ README.html 25 Jun 2004 09:01:57 -0000 1.2
@@ -1,94 +1,95 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2 Final//EN">
-<html>
-<head>
- <title>Index of /grass57/binary/linux</title>
-</head>
-<body>
-<h1>How to install the Linux (x86/Intel) binary code for
- GRASS 5.7.x EXPERIMENTAL in gzipped tar format.</h1>
+<HTML>
+ <HEAD>
+ <TITLE>GRASS 5.7.CVS experimental GNU/Linux binaries</TITLE>
+ </HEAD>
+ <BODY>
+<H1>GRASS 5.7.CVS experimental GNU/Linux binaries</H1>
-<h2>Note that this binary version may not work.<br>
- Use at your own risk.</h2>
+<h2>How to install the Linux (x86/Intel) binary code for
+GRASS 5.7.x EXPERIMENTAL in gzipped tar format.</h2>
+<h3>Note that this binary version may not work.<br>
+Use at your own risk. It's generated weekly from CVS.</h3>
You can install and use GRASS 5.7 in parallel to GRASS 5.0/5.3.
<h3>Installation:</h3>
<ol>
- <li>get the file <br>
-grass57-DD-MM-YYYY-arch-bin.tar.gz</li>
- <li>get the installation script <br>
-grass57-DD-MM-YYYY-arch-install.sh</li>
+ <li>get the file <br>grass-5.7.cvs-ARCH-DD_MM_YYYY.tar.gz</li>
+ <li>get the installation script <br> grass-5.7.cvs-ARCH-DD_MM_YYYY-install.sh</li>
</ol>
<h4>where</h4>
<ul>
- <li>DD-MM-YYYY is the date of the release (e.g. 10_02_2004)</li>
- <li>arc is the architecture of your platform (e.g. pc-linux-gnu)</li>
+ <li>ARCH is the architecture of the platform (e.g. i686-pc-linux-gnu)</li>
+ <li>DD-MM-YYYY is the date of the release (e.g. 21_06_2004)</li>
</ul>
-<strong>Note</strong>: this code is highly experimental and may be
-malfunctioning.<br>
-<br>
+<strong>Note</strong>: this code is highly experimental and may be malfunctioning.<br><br>
For installation, run the install script with --help option:<br>
-<ul>
- <li>sh grass57-DD-MM-YYYY-arch-install.sh --help </li>
-or <li>./grass57-DD-MM-YYYY-arch-install.sh --help </li>
-</ul>
-<br>
+ <ul>
+ <li>sh grass-5.7.cvs-ARCH-DD_MM_YYYY-install.sh --help </li>
+ or
+ <li>./grass-5.7.cvs-ARCH-DD_MM_YYYY-install.sh --help </li>
+</ul><br>
Or without help, directly:<br>
-<ul>
-grass57-DD-MM-YYYY-arc-bin.tar.gz</li>
+ <ul>
+ <li>sh grass-5.7.cvs-ARCH-DD_MM_YYYY-install.sh grass57-DD-MM-YYYY-arc-bin.tar.gz</li>
+ or
+ <li>./grass-5.7.cvs-ARCH-DD_MM_YYYY-install.sh grass57-DD-MM-YYYY-arc-bin.tar.gz</li>
</ul>
<h3>Libraries</h3>
The following libraries are required:
<ul>
- <li>libpq (e.g. libpq3-7.3.4-2mdk.i586.rpm)</li>
- <li>proj (e.g. proj-4.4.7-1mdk.i586.rpm)</li>
- <li>libproj (e.g. libproj0-4.4.7-1mdk.i586.rpm) </li>
- <li>libgdal(e.g. libgdal0-1.1.9-2mdk.i586.rpm) </li>
+ <li>libpq (e.g. libpq3 for Debian, libpq3-7.3.4-2mdk.i586.rpm for Mandrake) </li>
+ <li>libproj (e.g. proj for Debian, libproj0-4.4.7-1mdk.i586.rpm for Mandrake) </li>
+ <li>libgdal (e.g. libgdal1 for Debian, libgdal0-1.1.9-2mdk.i586.rpm for Mandrake) </li>
</ul>
+plus the program xterm.<br>
and, recommended, also:
-<ul>
- <li>tcl (e.g. tcl-8.3.3-21mdk.i586.rpm)</li>
- <li>tk (e.g. tk-8.3.3-21mdk.i586.rpm)</li>
- <li>gdal tools (e.g. gdal-1.1.9-2mdk.i586.rpm)</li>
- <li>libfftw (must be fft2, e.g. libfftw2-2.1.5-2mdk.i586.rpm)</li>
- <li>libgrass (e.g. libgrass5-1.0.0-1mdk.src.rpm - but only if inserted in one of above packages as dependency)<br>
- </li>
-</ul>
-optional:<br>
-<ul>
- <li>libgdal0-devel-1.1.9-2mdk.i586.rpm</li>
- <li>libgrass5_0-devel-1.0.0-1mdk.i586.rpm</li>
- <li>libproj0-devel-4.4.7-1mdk.i586.rpm</li>
+ <ul>
+ <li>tcl (e.g.tcl8.4 for Debian, tcl-8.3.3-21mdk.i586.rpm for Mandrake)</li>
+ <li>tk (e.g. tk8.4 for Debian, tk-8.3.3-21mdk.i586.rpm for Mandrake)</li>
+ <li>gdal tools (e.g. gdal-bin for Debian, gdal-1.1.9-2mdk.i586.rpm for Mandrake)</li>
+ <li>libfftw (must be fft2, e.g. fftw2 for Debian, libfftw2-2.1.5-2mdk.i586.rpm for Mandrake)</li>
</ul>
-You can find these RPMs on <a href="http://www.rpmfind.net/">www.rpmfind.net</a>
<h3>NOTE:</h3>
-In some distributions (e.g. Mandrake) the names of libraries is
-slightly different. Check, and if there is no file of the name:<br>
+In some distributions (e.g. Debian, Mandrake) the names of libraries are slightly different.
+Check, and if there is no file of the name:<br>
libtk.so.0<br>
libtcl.so.0<br>
libpq.so.2<br>
-libgdal.1.1.so<br>
-<br>
-then you should type:<br>
-<br>
-su<br>
-ln -s /usr/lib/libtk.so /usr/lib/libtk.so.0<br>
-ln -s /usr/lib/libtcl.so /usr/lib/libtcl.so.0<br>
-ln -s /usr/lib/libpq.so.3 /usr/lib/libpq.so.2<br>
-ln -s /usr/lib/libgdal.1.1.so /usr/lib/libgdal.so.1<br>
-ldconfig
-<p>Instead of (or in addition to) libtk.so and libtcl.so, you might
- have libtk8.4.so and libtcl8.4.so. In this case, type instead:<br>
+libgdal.so.1<br>
+libdfftw.so.2<br>
<br>
-ln -s /usr/lib/libtk8.4.so /usr/lib/libtk.so.0<br>
-ln -s /usr/lib/libtcl8.4.so /usr/lib/libtcl.so.0<br>
-ldconfig<br>
-</p>
-<hr>Please help us and report bugs.<br>
-<a href="http://grass.itc.it/bugtracking/bugreport.html">Bug report form</a>
+then you should type:<br><br>
+ su<br>
+ ln -s /usr/lib/libtk.so /usr/lib/libtk.so.0<br>
+ ln -s /usr/lib/libtcl.so /usr/lib/libtcl.so.0<br>
+ ln -s /usr/lib/libpq.so.3 /usr/lib/libpq.so.2<br>
+ ln -s /usr/lib/libgdal.1.1.so /usr/lib/libgdal.so.1<br>
+ ln -s /usr/lib/libfftw.so.2 /usr/lib/libdfftw.so.2<br>
+ ldconfig<br>
+ As a first argument, you should put the names of the libraries you have in your distribution.<br>
+<p>
+As a first argument, you should put the names of the libraries you have in your distribution.<br>
+Instead of (or in addition to) libtk.so and libtcl.so, you might have
+libtk8.4.so and libtcl8.4.so. In this case, type instead:<br><br>
+ ln -s /usr/lib/libtk8.4.so /usr/lib/libtk.so.0<br>
+ ln -s /usr/lib/libtcl8.4.so /usr/lib/libtcl.so.0<br>
+ ldconfig<br>
+<h1>How to uninstall</h1>
+sh /usr/local/bin/grass5uninstall.sh<br>
+If it's not there, then:<br>
+rm -rf /usr/local/bin/grass57<br>
+rm -rf /usr/local/bin/grass57-DD-MM-YYYY<br>
+rm -rf /usr/local/grass57-DD-MM-YYYY<br>
+<hr>
+Please help us and report bugs.<br>
+<a href=http://grass.itc.it/bugtracking/bugreport.html>Bug report form</a>
</body>
</html>
+</BODY></HTML>
More information about the grass-web
