[GRASSweb-list]markus: web/grass57/source/snapshot README.html,1.11,1.12
grass at intevation.de
Tue Nov 9 12:08:41 EST 2004
Author: markus
Update of /grassrepository/web/grass57/source/snapshot
In directory doto:/tmp/cvs-serv11316/grass57/source/snapshot
Modified Files:
README.html
Log Message:
GRASS 5.3-CVS no longer required to compile 5.7
Index: README.html
RCS file: /grassrepository/web/grass57/source/snapshot/README.html,v
retrieving revision 1.11
retrieving revision 1.12
diff -u -d -r1.11 -r1.12
--- README.html 16 Aug 2004 13:33:05 -0000 1.11
+++ README.html 9 Nov 2004 17:08:39 -0000 1.12
@@ -13,7 +13,7 @@
<p>
<b>What's that?</b><p>
-[Note: Compilation of 5.7.x requires <a href=../../../grass53/source/snapshot_experimental/>5.3.x source code</a>]<p>
+[Note: Compilation of 5.7.x NO LONGER requires 5.3.x source code (11/2004)]<p>
If you are not interested to use the CVS program for directly accessing the
latest GRASS 5.7 source code, you can follow ongoing development by download a
@@ -28,12 +28,6 @@
<h2>Is this snapshot stable?</h2>
Occasionally, weekly snapshots may not work properly; in case, please revert
to a previous version.<p>
-<p>
-Note: The code requires the GRASS 5.3-CVS source code to compile as selected
-files will be automatically linked into the new code. This may change in
-future when the GRASS 5.7-CVS repository is extended with further libraries,
-raster modules etc.
<h2>Installation</h2>
More information about the grass-web
