[GRASSweb-list]markus: web/grass57/tutorial index.html,1.29,1.30
grass at intevation.de grass at intevation.de
Wed Nov 10 03:28:09 EST 2004
Author: markus
Update of /grassrepository/web/grass57/tutorial
In directory doto:/tmp/cvs-serv22657
Modified Files:
Log Message:
cosmetics
Index: index.html
RCS file: /grassrepository/web/grass57/tutorial/index.html,v
retrieving revision 1.29
retrieving revision 1.30
diff -u -d -r1.29 -r1.30
--- index.html	19 May 2004 15:19:14 -0000	1.29
+++ index.html	10 Nov 2004 08:28:07 -0000	1.30
@@ -22,13 +22,17 @@
 </H1></td></tr></table>
 <!-- END OF HEADER -->
-<i><b>README</b>
-<br>
-GRASS 5.7 is currently under development. In case the examples described here do
-not work properly, you are kindly invited to send us further examples and/or
-code bugfixes/enhancements.</i>
-<P>
+<p>
+The Free Software/Open Source GIS GRASS 5.7 is under development since 2002.
+Meanwhile it is fully operational and stabilizing quickly to
+become published as stable version for productional usage.<br>
+This tutorial tries to give you a hand to familiarize yourself with
+the improved functionality, especially in the vector engine and attribute
+management.
+<table>
+<tr><td width="60%">
 <form method="post" action="http://grass.itc.it/cgi-bin/htsearch">
 <font size=-1>
 Match: <select name=method>
@@ -60,9 +64,17 @@
 <input type="submit" value="Search">&nbsp;
 <input TYPE="reset"  VALUE="Clear">
 </form>
+</td>
+<td>
+<b>Disclaimer</b>
+<i>GRASS 5.7 is a development version. In case the examples described here do
+not work properly, you are kindly invited to send us further examples and/or
+code bugfixes/enhancements.</i>
+</td>
+</tr>
+</table>
-<h2>GRASS 5.7 Tutorial table of contents</h2>
+<h2>Table of contents</h2>
 <a name="toc"></a>
 <ol>
 <li><a href="intro.html">Introduction</a>
More information about the grass-web mailing list
