[GRASSweb-list]markus: web commercial.html,1.22,1.23 related_projects.html,1.26,1.27
grass at intevation.de grass at intevation.de
Fri Nov 19 06:25:46 EST 2004
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv15472
Modified Files:
	commercial.html related_projects.html
Log Message:
gdal.velocet.ca -> home.gdal.org
Index: commercial.html
RCS file: /grassrepository/web/commercial.html,v
retrieving revision 1.22
retrieving revision 1.23
diff -u -d -r1.22 -r1.23
--- commercial.html	7 Sep 2004 07:29:50 -0000	1.22
+++ commercial.html	19 Nov 2004 11:25:44 -0000	1.23
@@ -35,7 +35,7 @@
 <ul>
 <li>Canada: <a href=http://www.tekmap.ns.ca>TEKMap Consulting</a>
 <p>
-<li>Canada: <a href=http://gdal.velocet.ca/~warmerda/consult.html>Frank Warmerdam</a> (GDAL/OGR/PROJ4/...)
+<li>Canada: <a href=http://home.gdal.org/~warmerda/consult.html>Frank Warmerdam</a> (GDAL/OGR/PROJ4/...)
 <p>
 <li>Denmark: <a href=http://www.navicon.dk/>NAVICON CSE</a>
 <p>
Index: related_projects.html
RCS file: /grassrepository/web/related_projects.html,v
retrieving revision 1.26
retrieving revision 1.27
diff -u -d -r1.26 -r1.27
--- related_projects.html	24 Aug 2004 02:27:34 -0000	1.26
+++ related_projects.html	19 Nov 2004 11:25:44 -0000	1.27
@@ -24,7 +24,7 @@
 <ul>
 <li>GRASS:
 <ul>
-<li><a href=http://gdal.velocet.ca/projects/grass/>libgrass</a>: Standalone GRASS
+<li><a href=http://home.gdal.org/projects/grass/>libgrass</a>: Standalone GRASS
       5 I/O Library to directly read/write GRASS Databases.
      <br>The latest libgrass source is also available by anonymous CVS:
More information about the grass-web mailing list
