[GRASSweb-list]markus: web/faq shape_import.html,1.2,1.3
grass at intevation.de
Fri Nov 19 06:25:46 EST 2004
Author: markus
Update of /grassrepository/web/faq
In directory doto:/tmp/cvs-serv15472/faq
Modified Files:
shape_import.html
Log Message:
gdal.velocet.ca -> home.gdal.org
Index: shape_import.html
RCS file: /grassrepository/web/faq/shape_import.html,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- shape_import.html 30 Oct 2002 11:14:16 -0000 1.2
+++ shape_import.html 19 Nov 2004 11:25:44 -0000 1.3
@@ -5,13 +5,13 @@
<strong>
Import of ESRI SHAPE vector files into GRASS
</strong><p>
-[This applies to GRASS 5.0.x]<p>
+[This applies to GRASS 5.0.x; use v.in.ogr in GRASS >= 5.7]<p>
Currently there is only a "quick-and-dirty" way to import ESRI's vector
shape files into GRASS GIS:
<p>
<center>A "real" shape-file reader is ready (v.in.shape) and included in GRASS 5!
-- original site: <a href=http://gdal.velocet.ca/projects/grass/grass5.0beta/src.alpha/m.in.shape>Follow here</a>.</center>
+- original site: <a href=http://home.gdal.org/projects/grass/grass5.0beta/src.alpha/m.in.shape>Follow here</a>.</center>
<p>
<h2>If using GRASS 4.x you may continue...</h2>
@@ -21,7 +21,7 @@
1. Convert the SHAPE file to UNGENERATE format:
<pre>
Example:
- v.shp2gen roads.shp > roads.lin
+ v.shp2gen roads.shp > roads.lin
</pre>
<p>
@@ -67,4 +67,4 @@
<HR>
<A HREF="index.html">Go back to GRASS GIS FAQ...</A>
</body>
-</html>
\ No newline at end of file
+</html>
More information about the grass-web
