[GRASSweb-list]TESIS
Bernhard Reiter bernhard at intevation.de
Fri Oct 29 09:25:01 EDT 2004
Hello Soledad,
you have reached the mailinglist for GRASS webmasters.
The Grass project is quite huge and has many participants,
I would suggest that you join a user or a development mailinglist
and specifically ask there for what you want to know.
As to the operating systems, GRASS is best supported on GNU/Linux,
because this is what most developers probably use.
It can be made to run on any unix-like operating system and
to an extend Windows with Cygwin is similiar enough.
Regards,
	Bernhard
On Thu, Oct 28, 2004 at 07:41:52PM +0000, Soledad Pico Mantilla wrote:
> My name is Soledad Pico, I am student from the Catholic University in
> Ecuador, actually I am working with GRASS because I am doing tests with
> this software.
> I am studing about how work GRASS over diferents operative systems. For
> example Windows, Macintosh and Linux. Furthermore I am working with
> diferent data bases. For example Acces, Sql, Oracle and Mysql.
> I need to know how you can help me. If you can give me information about
> different test that you have about this.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-web/attachments/20041029/65659273/attachment.bin
More information about the grass-web mailing list
