[GRASSweb-list]markus: web/devel i18n.inc,1.9,1.10 i18n.php,1.4,1.5 i18n_stats.inc,1.9,1.10
grass at intevation.de
Fri Mar 18 10:44:20 EST 2005
Author: markus
Update of /grassrepository/web/devel
In directory doto:/tmp/cvs-serv7032
Modified Files:
i18n.inc i18n.php i18n_stats.inc
Log Message:
another try to explain how to participate
Index: i18n.inc
RCS file: /grassrepository/web/devel/i18n.inc,v
retrieving revision 1.9
retrieving revision 1.10
diff -u -d -r1.9 -r1.10
--- i18n.inc 9 Mar 2005 13:23:13 -0000 1.9
+++ i18n.inc 18 Mar 2005 15:44:18 -0000 1.10
@@ -39,8 +39,9 @@
README below):
<ol>
-<li>get a fresh (!) GRASS 6 from <a href="http://freegis.org/grass/grass-cvs.html">CVS</a>
- (or <a href=../grass60/source/snapshot/>6.0 CVS snapshot</a>)
+<li>Either get a fresh (!) GRASS 6 from <a href="http://freegis.org/grass/grass-cvs.html">CVS</a>
+ (or <a href=../grass60/source/snapshot/>6.0 CVS snapshot</a>)<br>
+ or download existing .po files (see below)
<li>run: '<tt>cd locale</tt>' to change into the translation directory
<li>run: '<tt>make pot</tt>' to create grass*.pot files (containing original messages)
<li>run: '<tt>make update-po</tt>' merge new messages into existing *.po files (or create new po files)
@@ -53,6 +54,15 @@
Translation <a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass6/locale/README?rev=HEAD&content-type=text/vnd.viewcvs-markup">README</a>
<P>
Once the procedure got stabilized, we'll extend this web page.
+<h3>Download of existing .po files</h3>
+<a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass6/locale/po/">Download current .po files</a>
+from CVS (useful if you want to partecipate without compiling GRASS). Please
+announce your efforts on the 'GRASS translations' mailing list (see above) to
+avoid that work is doubled. To start a new language, you can simply rewrite an
+existing file. Take care to rename it properly and to update the language specific
+metadata.
<a name="multibyte"></a>
<h3>Multi-byte FreeType/TrueType TTF support</h3>
Index: i18n.php
RCS file: /grassrepository/web/devel/i18n.php,v
retrieving revision 1.4
retrieving revision 1.5
diff -u -d -r1.4 -r1.5
--- i18n.php 31 Jan 2005 14:51:01 -0000 1.4
+++ i18n.php 18 Mar 2005 15:44:18 -0000 1.5
@@ -81,7 +81,7 @@
</table>
<hr>
- <div align="right">© 2004 GRASS Development Team<br>
+ <div align="right">© 2004-2005 GRASS Development Team<br>
<a href="../impressum.html">Imprint</a> |
<a href="../contact.php">Comments</a> about this page<br>
</div>
Index: i18n_stats.inc
RCS file: /grassrepository/web/devel/i18n_stats.inc,v
--- i18n_stats.inc 17 Mar 2005 17:34:22 -0000 1.9
+++ i18n_stats.inc 18 Mar 2005 15:44:18 -0000 1.10
@@ -78,13 +78,4 @@
The relevant column is 'Translated messages' as the message files
do not necessarily contain all available messages of GRASS.
-<h3>Download of existing .po files</h3>
-<a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass6/locale/po/">Download current .po files</a>
-from CVS (useful if you want to partecipate without compiling GRASS). Please
-announce your efforts on the 'GRASS translations' mailing list (see above) to
-avoid that work is doubled. To start a new language, you can simply rewrite an
-existing file. Take care to rename it properly and to update the language specific
-metadata.
</html>
More information about the grass-web
