[GRASSweb-list]markus: web/grass57 index.html,1.85,1.86
grass at intevation.de
Tue May 31 06:12:52 EDT 2005
Author: markus
Update of /grassrepository/web/grass57
In directory doto:/tmp/cvs-serv18177/grass57
Modified Files:
Log Message:
removed grass++ links
Index: index.html
RCS file: /grassrepository/web/grass57/index.html,v
retrieving revision 1.85
retrieving revision 1.86
diff -u -d -r1.85 -r1.86
--- index.html 20 Mar 2005 14:57:30 -0000 1.85
+++ index.html 31 May 2005 10:12:50 -0000 1.86
@@ -194,10 +194,7 @@
<li> GRASS as Web server application (client/server architectures)</li>
<li> <a href="grass51_vector_discussion.txt">Protocol of a features discussion</a></li>
</ul>
-<li><a href=http://mpa.itc.it/radim/grass++/index.html>GRASS++ library</a>: GRASS++ is experimental C++ open source library,
- which may be used in C++ programs, to access GRASS data. Currently GRASS++ contains only few
- classes for basic setup and GRASS 5.7 raster and vector reading. Used for example in the
- <a href=http://mpa.itc.it/radim/qgis/index.html>GRASS/QGIS integration</a>.
+<li> <a href=http://mpa.itc.it/radim/qgis/index.html>GRASS/QGIS integration</a>.
<li> Feel free to contact and join the <a href="../devel/index.php">GRASS Development Team</a>!
</ul>
More information about the grass-web
