[GRASSweb-list]markus: web/intro related_projects.html,1.2,1.3
grass at intevation.de grass at intevation.de
Tue May 31 06:12:52 EDT 2005
Author: markus
Update of /grassrepository/web/intro
In directory doto:/tmp/cvs-serv18177/intro
Modified Files:
Log Message:
removed grass++ links
Index: related_projects.html
RCS file: /grassrepository/web/intro/related_projects.html,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- related_projects.html	10 Jan 2005 16:42:26 -0000	1.2
+++ related_projects.html	31 May 2005 10:12:50 -0000	1.3
@@ -25,40 +25,28 @@
 <li>GRASS:
 <ul>
 <li><a href=http://home.gdal.org/projects/grass/>libgrass</a>: Standalone GRASS
-      5 I/O Library to directly read/write GRASS Databases.
-     <br>The latest libgrass source is also available by anonymous CVS:
-<pre>     export CVSROOT=:pserver:grass-guest at intevation.de:/home/grass/grassrepository
-     cvs login
-     Password: grass
-     cvs checkout libgrass
-     The CVS tree can also be browsed on the <a href=http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/libgrass/>web</a>.</pre>
-    Compiling libgrass against GDAL allows to read GRASS 5 raster data
-    through GDAL (<a href=http://www.remotesensing.org/gdal/frmt_grass.html>see instructions</a>). Example usage: MapServer is able to read GRASS locations
+      5 I/O Library to directly read/write GRASS Databases. [Outdated!]
+    <br>
+     Recommended: GRASS/GDAL plugin (<a href=http://www.gdal.org/frmt_grass.html>here</a>). Example usage: MapServer is able to read GRASS locations
     directly.<br>
-    Visit the <a href=http://grass.itc.it/start.html>GRASS/MapServer Demo
+    Visit the <a href="http://grass.itc.it/start.html">GRASS/MapServer Demo
     site</a>!
-<li><a href=http://mpa.itc.it/radim/grass++/index.html>GRASS++</a>
-  GRASS++ is experimental C++ open source library, which may be used in C++
-  programs, to access GRASS data.
 </ul>
-<li><a href=http://www.remotesensing.org/proj/>PROJ 4</a>: Projection/datum support
+<li><a href="http://proj.maptools.org">PROJ 4</a>: Projection/datum support
   library. It also provides the 'cs2cs' software which reprojects x,y [,z]
   coordinate lists including datum transformation.
-<li><a href=http://www.remotesensing.org/gdal/>GDAL</a>: Geospatial Data
+<li><a href="http://www.gdal.org/">GDAL</a>: Geospatial Data
      Abstraction Library (raster)
-<li><a href=http://www.remotesensing.org/gdal/ogr/>OGR</a>: OGR Simple Features Library
+<li><a href="http://www.gdal.org/ogr/">OGR</a>: OGR Simple Features Library
      (vector)
-<li><a href=http://pweb.jps.net/~egm2/grass/xml/>GRASS XML pages</a> for
- <a href=http://www.w3.org/XML/>XML</a> (Extensible Markup Language) support
+<li><a href="http://pweb.jps.net/~egm2/grass/xml/">GRASS XML pages</a> for
+ <a href="http://www.w3.org/XML/">XML</a> (Extensible Markup Language) support
 </ul>
 <a name="other"></a>
 <h2>Other projects</h2>
 <ul>
-<li><a href=http://www.freegis.org>FreeGIS</a>: Link collection of
+<li><a href="http://www.freegis.org">FreeGIS</a>: Link collection of
 	Free Software for geographic information processing and
 	data sources with similiar freedoms.
 <li><a href="http://thuban.intevation.org/">Thuban</a>:
More information about the grass-web mailing list
