[GRASSweb-list] markus: web/grass61/binary/linux README.html, 1.2,
1.3
grass at intevation.de
Mon Aug 7 16:53:15 EDT 2006
Author: markus
Update of /grassrepository/web/grass61/binary/linux
In directory doto:/tmp/cvs-serv9186
Modified Files:
README.html
Log Message:
clarified 64bit issue
Index: README.html
RCS file: /grassrepository/web/grass61/binary/linux/README.html,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- README.html 28 Mar 2006 07:43:23 -0000 1.2
+++ README.html 7 Aug 2006 20:53:13 -0000 1.3
@@ -4,12 +4,15 @@
<title>GRASS 6.1.x binary releases for GNU/Linux</title>
</head>
<body>
-<h1>How to install the Linux (x86/Intel) binary releases
- of GRASS 6.1.x in gzipped tar format.</h1>
+<h1>How to install the Linux binary releases of GRASS 6.1.x in gzipped tar format.</h1>
<h2>Use at your own risk.</h2>
-You can install and use GRASS 6.1.x in parallel to GRASS 5.0/5.3/5.4.
+<b>Note: the x86_64 binaries will only run on 64bit CPUs (use 'uname -m' to
+find out about your computer).</b>
+<p>
+You can install and use GRASS 6.1.x in parallel to GRASS 5.x.
<h3>Installation:</h3>
<ol>
<li>get the file <br>
More information about the grass-web
