[GRASSweb-list] markus: web/grass61/binary/linux/snapshot
README.html, 1.2, 1.3
grass at intevation.de
Mon Aug 7 16:54:09 EDT 2006
Author: markus
Update of /grassrepository/web/grass61/binary/linux/snapshot
In directory doto:/tmp/cvs-serv9204
Modified Files:
README.html
Log Message:
clarified 64bit issue
Index: README.html
RCS file: /grassrepository/web/grass61/binary/linux/snapshot/README.html,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- README.html 28 Mar 2006 07:43:23 -0000 1.2
+++ README.html 7 Aug 2006 20:54:07 -0000 1.3
@@ -11,10 +11,10 @@
<h2>How to install the Linux (x86/Intel) binary code for
GRASS 6.1.cvs EXPERIMENTAL in gzipped tar format.</h2>
-<b>Note: Occasionally, weekly snapshots may not work properly; in
-case, please revert to a previous version.</b>
-<P>
-You can install and use GRASS 6 in parallel to GRASS 5.0/5.4.
+<b>Note: the x86_64 binaries will only run on 64bit CPUs (use 'uname -m' to
+find out about your computer).</b>
+<p>
+You can install and use GRASS 6 in parallel to GRASS 5.x.
<h3>Installation:</h3>
<ol>
More information about the grass-web
