[GRASSweb-list] Re: some problem in running rsync-2.6.8
Markus Neteler neteler at itc.it
Wed Aug 16 05:59:56 EDT 2006
Great, good to know!
thanks for mirroring us,
 Markus
On Wed, Aug 16, 2006 at 04:01:32PM +0900, Lee,Chun-Seok wrote:
> I'm so sorry..
> I've solved the problem.. it was just because my firewall was blocking the dns responces from outside..
> The rsync seems to work..!!
>   ----- Original Message -----
>   From: Lee,Chun-Seok
>   To: weblist at grass.itc.it
>   Sent: Wednesday, August 16, 2006 2:47 PM
>   Subject: some problem in running rsync-2.6.8
>   Hello!
>   My grass mirroring machine of korea named pinus.chinju.ac.kr was perfectly dead last month by the thunder.
>   So I've changed it to a new machine which  has sufficient room and speed already.
>   but, I have some problem in running the rsync to mirror ibiblio.org::grass.
>   please help me to continue the mirroring.. How can i do and What should I do?
>   Details;
>   machine : Intel dual cpu xeon 3.4Ghz
>   OS : Linux x86_64 (asianux2) kernel 2.6.9  with ssh
>   host name : pinus.chinju.ac.kr
>   local grass ftp dir : /var/ftp/pub/grass
>   firewall : running iptables
>   rsync 2.6.8 <-compiled by gcc using source files.
>   cronnning daily using following sentences;
>      /usr/local/rsync/bin/rsync -r --delete --times --links --bwlimit=200  ibiblio.org::grass /var/ftp/pub/grass
>   the error messages;
>      rsync: getaddrinfo: ibiblio.org 873: Temporary failure in name resolution
>      rsync error: error in socket IO (code 10) at clientserver.c(107) [receiver=2.6.8]
>   Lee,Chun-Seok   Ph.D
>   mailto:stoney at jinju.ac.kr
>   TEL : +82-55-751-3305
>   MBL : +82-18-232-5846
>   FAX : +82-55-751-3309
More information about the grass-web mailing list
