[GRASSweb-list] Re: some problem in running rsync-2.6.8
Lee,Chun-Seok stoney at jinju.ac.kr
Wed Aug 16 03:01:32 EDT 2006
I'm so sorry..
I've solved the problem.. it was just because my firewall was blocking the dns responces from outside..
The rsync seems to work..!!
  ----- Original Message -----
  To: weblist at grass.itc.it
  Sent: Wednesday, August 16, 2006 2:47 PM
  Subject: some problem in running rsync-2.6.8
  Hello!
  My grass mirroring machine of korea named pinus.chinju.ac.kr was perfectly dead last month by the thunder.
  So I've changed it to a new machine which  has sufficient room and speed already.
  but, I have some problem in running the rsync to mirror ibiblio.org::grass.
  please help me to continue the mirroring.. How can i do and What should I do?
  Details;
  machine : Intel dual cpu xeon 3.4Ghz
  OS : Linux x86_64 (asianux2) kernel 2.6.9  with ssh
  host name : pinus.chinju.ac.kr
  local grass ftp dir : /var/ftp/pub/grass
  firewall : running iptables
  rsync 2.6.8 <-compiled by gcc using source files.
  cronnning daily using following sentences;
     /usr/local/rsync/bin/rsync -r --delete --times --links --bwlimit=200  ibiblio.org::grass /var/ftp/pub/grass
  the error messages;
     rsync: getaddrinfo: ibiblio.org 873: Temporary failure in name resolution
     rsync error: error in socket IO (code 10) at clientserver.c(107) [receiver=2.6.8]
  Lee,Chun-Seok   Ph.D
  mailto:stoney at jinju.ac.kr
  TEL : +82-55-751-3305
  MBL : +82-18-232-5846
  FAX : +82-55-751-3309
URL: http://lists.osgeo.org/pipermail/grass-web/attachments/20060816/d1d4fa53/attachment.html
More information about the grass-web mailing list
