[GRASSweb-list]markus: web/devel devel.inc,1.21,1.22
grass at intevation.de
Sun Jan 15 15:44:31 EST 2006
- Previous message: [GRASSweb-list]markus: web main_menu_side.inc,1.10,1.11
- Next message: [GRASSweb-list]markus: web/newsletter GRASSNews_vol3_erratum.pdf,1.1,1.2 GRASSNews_vol3_erratum.txt,1.1,1.2 grassnews3-bib.html,1.2,1.3 grassnews3.bib,1.1,1.2 grassnews3.html,1.2,1.3 newsletter.inc,1.11,1.12
- Messages sorted by:
[ date ]
[ thread ]
[ subject ]
[ author ]
Author: markus
Update of /grassrepository/web/devel
In directory doto:/tmp/cvs-serv5665
Modified Files:
devel.inc
Log Message:
updated
Index: devel.inc
RCS file: /grassrepository/web/devel/devel.inc,v
retrieving revision 1.21
retrieving revision 1.22
diff -u -d -r1.21 -r1.22
--- devel.inc 4 Jan 2006 16:36:34 -0000 1.21
+++ devel.inc 15 Jan 2006 20:44:29 -0000 1.22
@@ -149,22 +149,27 @@
(which you find in the GRASS source code).
<ul>
-<li> Coding standards: Check your code against the rules defined in the
+<li> C language Coding standards: Check your code against the rules defined in the
'SUBMITTING' file (find it in the main directory of the GRASS source
code and also <a href=../grass61/source/SUBMITTING>here</a>). This ensures
a smooth integration into the standard GRASS code base.
+<li> Shell script Coding standards: Check your code against the rules defined in the
+ 'SUBMITTING_SCRIPTS' file (find it in the main directory of the GRASS source
+ code and also <a href=../grass61/source/SUBMITTING_SCRIPTS>here</a>). This ensures
+ a smooth integration into the standard GRASS code base and avoids portability
+ problems.
<li> Code submission: Please contact a member of the
- <A HREF="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass/AUTHORS">GRASS Development Team</a>
+ <A HREF="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass6/AUTHORS">GRASS Development Team</a>
or write to the development mailing list (see <A HREF="#list">above</a>).<br>
In general, please generate differences to the current CVS instead of sending
full files:<br>
- <tt>cvs diff [file.c] > diff</tt><br>
- This file 'diff' you may send to a member of the
- <A HREF="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass/AUTHORS">GRASS Development Team</a>.
-<li> GRASS Add-on submission: <a href=../download/addons.php>go here</a> (Add-on code
+ <tt>cvs diff -u [file.c] > grassdiff</tt><br>
+ This file 'grassdiff' you may send to a member of the
+ <A HREF="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass6/AUTHORS">GRASS Development Team</a>.
+<li> GRASS Add-on submission: <a href="http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassAddOns">go here</a> (Add-on code
is hosted on your server)
-<li> Alredy submitted code which is not (yet) integrated: <a href=../outgoing/>OUTGOING
- directory</a>
+<li> Already submitted code which is not (yet) integrated: <a href=../outgoing/>OUTGOING
+ directory</a> - maybe you can work on this?
<li> GRASS <a href="http://freegis.org//grass/howto_grass-sshcvs.en.html">CVS write access</a> for developers
</ul>
[ date ]
[ thread ]
[ subject ]
[ author ]
More information about the grass-web
