[GRASSweb-list]markus: web/newsletter GRASSNews_vol3_erratum.pdf,1.1,1.2 GRASSNews_vol3_erratum.txt,1.1,1.2 grassnews3-bib.html,1.2,1.3 grassnews3.bib,1.1,1.2 grassnews3.html,1.2,1.3 newsletter.inc,1.11,1.12
    grass at intevation.de
    Mon Jan 16 03:52:07 EST 2006
Author: markus
Update of /grassrepository/web/newsletter
In directory doto:/tmp/cvs-serv16786
Modified Files:
	GRASSNews_vol3_erratum.pdf GRASSNews_vol3_erratum.txt
	grassnews3-bib.html grassnews3.bib grassnews3.html
	newsletter.inc
Log Message:
new SRTM erratum added
Index: GRASSNews_vol3_erratum.pdf
RCS file: /grassrepository/web/newsletter/GRASSNews_vol3_erratum.pdf,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
Binary files /tmp/cvsWiOwz0 and /tmp/cvs46rPcR differ
Index: GRASSNews_vol3_erratum.txt
RCS file: /grassrepository/web/newsletter/GRASSNews_vol3_erratum.txt,v
--- GRASSNews_vol3_erratum.txt	27 Jun 2005 08:24:15 -0000	1.1
+++ GRASSNews_vol3_erratum.txt	16 Jan 2006 08:52:05 -0000	1.2
@@ -1,20 +1,40 @@
 Erratum of GRASS-News vol. 3 (June 2005)
+ $Date$
+_________________________________________________________________
+SRTM and VMAP0 data in OGR and GRASS. GRASS Newsletter, 3:2-6, 2005
+(M. Neteler)
+Problem: The first 'find' command in Figure 3 'Shell code to fix the original
+         VMAP0 file/directory names for OGDI/OGR usage' does not work
+         on MaxOSX.
+Solution: Add a dot after the find:
+  old:
+      find -name '*.' > /tmp/vm_list1
+  correct:
+      find . -name '*.' > /tmp/vm_list1
+(added Jan 2006)
 Interfacing GRASS 6 and R
 (R. Bivand)
 Problem: select CRAN mirror without X11 running
+Solution:
 - development files for gdal are necessary (e.g. for a Debian box,
 apt-get install libgdal-dev)
 - in case you get the error: --- Please select a CRAN mirror for use in this session ---
-(when a graphic monitor is not available for whathever reason, e.g. in case of remote installations)
---  add the address of a CRAN mirror to your install command, e. g. install.packages(c("sp","rgdal"), dependencies=TRUE,
-repos="http://microarrays.unife.it/CRAN/")
+  (when a graphic monitor is not available for whathever reason, e.g.
+  in case of remote installations)
+--  add the address of a CRAN mirror to your install command,
+    e.g. install.packages(c("sp","rgdal"), dependencies=TRUE, repos="http://microarrays.unife.it/CRAN/")
 -- alternatively, one could set the search of cran mirror to non-graphic, by
-typing: chooseCRANmirror(graphics=FALSE) before the install command.
+    typing: chooseCRANmirror(graphics=FALSE) before the install command.
 (added June 2005)
 ________________
Index: grassnews3-bib.html
RCS file: /grassrepository/web/newsletter/grassnews3-bib.html,v
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- grassnews3-bib.html	20 Jun 2005 01:50:52 -0000	1.2
+++ grassnews3-bib.html	16 Jan 2006 08:52:05 -0000	1.3
@@ -1,4 +1,15 @@
-<h1>grassnews3.bib</h1><pre><a name="neteler2005srtm_vmap0"></a>@ARTICLE{neteler2005srtm_vmap0,
+<H1>grassnews3.bib</H1><PRE><A NAME="erratum"></A>
+ at ARTICLE{erratum,
+  TITLE = {Erratum},
+  JOURNAL = {GRASS Newsletter},
+  YEAR = {2005},
+  VOLUME = {3},
+  MONTH = {June},
+  LINK = {http://grass.itc.it/newsletter/GRASSNews_vol3_erratum.pdf}
+<A NAME="neteler2005srtm_vmap0"></A>
+ at ARTICLE{neteler2005srtm_vmap0,
   AUTHOR = {M. Neteler},
   TITLE = {{SRTM} and {VMAP0} data in {OGR} and {GRASS}},
@@ -7,10 +18,11 @@
   PAGES = {2-6},
   NOTE = {ISSN 1614-8746},
   MONTH = {June},
-  LINK = {<a href="http://grass.itc.it/newsletter/GRASSNews_vol3.pdf">http://grass.itc.it/newsletter/GRASSNews_vol3.pdf</a>}
+  LINK = {http://grass.itc.it/newsletter/GRASSNews_vol3.pdf}
-<a name="Bowman2005"></a>@ARTICLE{Bowman2005,
+<A NAME="Bowman2005"></A>
+ at ARTICLE{Bowman2005,
   AUTHOR = {M.H. Bowman},
   TITLE = {Mapping freely available high resolution
             global elevation and vector data in {GRASS}},
@@ -20,10 +32,11 @@
   PAGES = {7-10},
   MONTH = {June},
-<a name="Bivand2005"></a>@ARTICLE{Bivand2005,
+<A NAME="Bivand2005"></A>
+ at ARTICLE{Bivand2005,
   AUTHOR = {R. Bivand},
   TITLE = {Interfacing {GRASS} 6 and {R}},
@@ -32,10 +45,11 @@
   PAGES = {11-16},
   MONTH = {June},
-<a name="Lorenz2005"></a>@ARTICLE{Lorenz2005,
+<A NAME="Lorenz2005"></A>
+ at ARTICLE{Lorenz2005,
   AUTHOR = {G. Lorenz},
   TITLE = {Use of {R} tightly coupled to {GRASS} for correction of
            single-detector errors in {EO1} hyperspectral images},
@@ -45,10 +59,11 @@
   PAGES = {16-18},
   MONTH = {June},
-<a name="Loewe2005"></a>@ARTICLE{Loewe2005,
+<A NAME="Loewe2005"></A>
+ at ARTICLE{Loewe2005,
   AUTHOR = {P. Loewe},
   TITLE = {Knowledge Management and {GRASS GIS}: r.infer},
@@ -57,10 +72,11 @@
   PAGES = {19-21},
   MONTH = {June},
-<a name="ShermanSutton2005"></a>@ARTICLE{ShermanSutton2005,
+<A NAME="ShermanSutton2005"></A>
+ at ARTICLE{ShermanSutton2005,
   AUTHOR = {G.E. Sherman and T. Sutton},
   TITLE = {Quantum {GIS}},
@@ -69,10 +85,11 @@
   PAGES = {21-23},
   MONTH = {June},
-<a name="Ducke2006"></a>@ARTICLE{Ducke2006,
+<A NAME="Ducke2006"></A>
+ at ARTICLE{Ducke2006,
   AUTHOR = {B.Ducke},
   TITLE = {{GRASS} 6 Extensions Manager in development},
@@ -81,7 +98,7 @@
   PAGES = {23-24},
   MONTH = {June},
-</pre>
\ No newline at end of file
+</PRE>
Index: grassnews3.bib
RCS file: /grassrepository/web/newsletter/grassnews3.bib,v
--- grassnews3.bib	20 Jun 2005 01:42:33 -0000	1.1
+++ grassnews3.bib	16 Jan 2006 08:52:05 -0000	1.2
@@ -1,3 +1,12 @@
+ YEAR = {2005},
+ VOLUME = {3},
+ MONTH = {June},
Index: grassnews3.html
RCS file: /grassrepository/web/newsletter/grassnews3.html,v
--- grassnews3.html	20 Jun 2005 01:50:52 -0000	1.2
+++ grassnews3.html	16 Jan 2006 08:52:05 -0000	1.3
@@ -1,121 +1,143 @@
-<!-- This document was automatically generated with bibtex2html 1.65
+<!-- This document was automatically generated with bibtex2html 1.52
      (see http://www.lri.fr/~filliatr/bibtex2html/),
      with the following command:
-     bibtex2html -f link -nodoc -nofooter grassnews3.bib  -->
+     /nfsmnt/mpa_sw/ssi/BIO/software/bibtex2html-1.52-linux/bibtex2html -f link -nodoc -nofooter grassnews3.bib  -->
 <table>
-<tr valign="top">
-<td align="right">
-<a name="neteler2005srtm_vmap0"></a>[1]
+<tr valign=top>
+<td align=right>
+<A NAME="erratum"></A>
+[1]
 </td>
 <td>
-M. Neteler.
+Erratum.
+  <i>GRASS Newsletter</i>, 3, June 2005.<BR>
+[ <A HREF="./grassnews3-bib.html#erratum">bib</A> |
+<A HREF="http://grass.itc.it/newsletter/GRASSNews_vol3_erratum.pdf">.pdf</A> ]
+</td>
+</tr>
+<tr valign=top>
+<td align=right>
+[2]
+</td>
+<td>
+M. Neteler.
   <i>GRASS Newsletter</i>, 3:2-6, June 2005.
-  ISSN 1614-8746.<br />
-[ <a href="./grassnews3-bib.html#neteler2005srtm_vmap0">bib</a> |
-<a href="http://grass.itc.it/newsletter/GRASSNews_vol3.pdf">.pdf</a> ]
+  ISSN 1614-8746.<BR>
+[ <A HREF="./grassnews3-bib.html#neteler2005srtm_vmap0">bib</A> |
+<A HREF="http://grass.itc.it/newsletter/GRASSNews_vol3.pdf">.pdf</A> ]
 </td>
 </tr>
-<tr valign="top">
-<td align="right">
-<a name="Bowman2005"></a>[2]
+<tr valign=top>
+<td align=right>
+[3]
 </td>
 <td>
 M.H. Bowman.
   Mapping freely available high resolution global elevation and vector
   data in GRASS.
   <i>GRASS Newsletter</i>, 3:7-10, June 2005.
-[ <a href="./grassnews3-bib.html#Bowman2005">bib</a> |
+[ <A HREF="./grassnews3-bib.html#Bowman2005">bib</A> |
 </td>
 </tr>
-<tr valign="top">
-<td align="right">
-<a name="Bivand2005"></a>[3]
+<tr valign=top>
+<td align=right>
+[4]
 </td>
 <td>
-R. Bivand.
+R. Bivand.
   Interfacing GRASS 6 and R.
   <i>GRASS Newsletter</i>, 3:11-16, June 2005.
-[ <a href="./grassnews3-bib.html#Bivand2005">bib</a> |
+[ <A HREF="./grassnews3-bib.html#Bivand2005">bib</A> |
 </td>
 </tr>
-<tr valign="top">
-<td align="right">
-<a name="Lorenz2005"></a>[4]
+<tr valign=top>
+<td align=right>
+[5]
 </td>
 <td>
-G. Lorenz.
+G. Lorenz.
   Use of R tightly coupled to GRASS for correction of
   single-detector errors in EO1 hyperspectral images.
   <i>GRASS Newsletter</i>, 3:16-18, June 2005.
-[ <a href="./grassnews3-bib.html#Lorenz2005">bib</a> |
+[ <A HREF="./grassnews3-bib.html#Lorenz2005">bib</A> |
 </td>
 </tr>
-<tr valign="top">
-<td align="right">
-<a name="Loewe2005"></a>[5]
+<tr valign=top>
+<td align=right>
+[6]
 </td>
 <td>
-P. Loewe.
+P. Loewe.
   Knowledge management and GRASS GIS: r.infer.
   <i>GRASS Newsletter</i>, 3:19-21, June 2005.
-[ <a href="./grassnews3-bib.html#Loewe2005">bib</a> |
+[ <A HREF="./grassnews3-bib.html#Loewe2005">bib</A> |
 </td>
 </tr>
-<tr valign="top">
-<td align="right">
-<a name="ShermanSutton2005"></a>[6]
+<tr valign=top>
+<td align=right>
+[7]
 </td>
 <td>
-G.E. Sherman and T. Sutton.
+G.E. Sherman and T. Sutton.
   Quantum GIS.
   <i>GRASS Newsletter</i>, 3:21-23, June 2005.
-[ <a href="./grassnews3-bib.html#ShermanSutton2005">bib</a> |
+[ <A HREF="./grassnews3-bib.html#ShermanSutton2005">bib</A> |
 </td>
 </tr>
-<tr valign="top">
-<td align="right">
-<a name="Ducke2006"></a>[7]
+<tr valign=top>
+<td align=right>
+[8]
 </td>
 <td>
 B.Ducke.
   GRASS 6 extensions manager in development.
   <i>GRASS Newsletter</i>, 3:23-24, June 2005.
-[ <a href="./grassnews3-bib.html#Ducke2006">bib</a> |
+[ <A HREF="./grassnews3-bib.html#Ducke2006">bib</A> |
 </td>
 </tr>
Index: newsletter.inc
RCS file: /grassrepository/web/newsletter/newsletter.inc,v
retrieving revision 1.11
retrieving revision 1.12
diff -u -d -r1.11 -r1.12
--- newsletter.inc	14 Nov 2005 08:03:40 -0000	1.11
+++ newsletter.inc	16 Jan 2006 08:52:05 -0000	1.12
@@ -72,7 +72,7 @@
  <b>GRASS Newsletter vol. 3 (June 2005)</b><br>
  <a href="grassnews3.html">Contents</a> |
  <a href="GRASSNews_vol3.pdf">PDF</a> (1 MB) |
-  erratum <a href="GRASSNews_vol3_erratum.pdf">(pdf)</a> <a href="GRASSNews_vol3_erratum.txt">(txt)</a>  |
+  Erratum 1/2006 <a href="GRASSNews_vol3_erratum.pdf">(pdf)</a> <a href="GRASSNews_vol3_erratum.txt">(txt)</a>  |
  <a href="grassnews3.bib">Bibtex file</a>
 </ul>
More information about the grass-web
