[GRASSweb-list]markus: web/download software.inc,1.40,1.41
    grass at intevation.de
    Wed Jan 25 08:33:42 EST 2006
Author: markus
Update of /grassrepository/web/download
In directory doto:/tmp/cvs-serv21847
Modified Files:
	software.inc
Log Message:
cvs server added; cosmetics
Index: software.inc
RCS file: /grassrepository/web/download/software.inc,v
retrieving revision 1.40
retrieving revision 1.41
diff -u -d -r1.40 -r1.41
--- software.inc	16 Jan 2006 12:13:37 -0000	1.40
+++ software.inc	25 Jan 2006 13:33:40 -0000	1.41
@@ -1,17 +1,21 @@
 <!-- MN -->
 [ <A HREF="#software">Software</A> -
- <A HREF="#citing">Citing GRASS</A>
+  <A HREF="#cvs">CVS Server</A> -
+  <A HREF="#requirements">Requirements</A> -
+  <A HREF="#citing">Citing GRASS</A>
+<hr>
 <h3>Software</h3>
 <a name="software"></a>
-<i>
-Please use the <a href="../mirrors.php">GRASS mirror site</a> next to you.
-</i>
-<p>
+Download "<b>Binaries</b>": if you want to install ready-to-use GRASS.<br>
+Download "<b>Source Code</b>": if you want to develop own GRASS extensions or run
+GRASS on a special computer platform.<br>
+<i>Please use the <a href="../mirrors.php">GRASS mirror site</a> next to you.</i>
+<P>
 <table BORDER WIDTH="100%" CELLPADDING=5 CELLSPACING=3 NOSAVE >
 <tr NOSAVE>
@@ -138,13 +142,34 @@
 </table>
-<br><a href="../grass60/source/REQUIREMENTS.html" NAME="requirements">Installation
-requirements (needed libraries)</a> -<a href="../faq/cvs_howto.html">
-CVS/GRASS FAQ</a>
+<a name="cvs"></a>
+<h3>Download from CVS</h3>
+The GRASS source code is also available by anonymous CVS from the intevation.de server:
+<small>
+<pre>
+  export CVSROOT=:pserver:grass-guest at intevation.de:/home/grass/grassrepository
+  cvs login
+  #password: "grass" (without quotes)
+  cvs -z3 checkout grass6
+  #Subsequent updates:
+  cvs up -dP
+</pre>
+</small>
+<hr>
+<a name="requirements"></a>
+<h3>Requirements</h3>
+<a href="../grass60/source/REQUIREMENTS.html" NAME="requirements">Installation
+requirements (needed libraries)</a> -
+<a href="../faq/cvs_howto.html">CVS/GRASS FAQ</a>
 From here you can download all GRASS software, source codes, binaries,
 manuals, and datasets. Most documentation is in PDF format, so you
-will need to download
+will need to download:
 <a href="http://www.foolabs.com/xpdf/" target="_top">xPDF</a> or
 <a href="http://www.cs.wisc.edu/~ghost/">Ghostview</a> or
@@ -155,12 +180,7 @@
 go to the <a href="../gdp/index.php">GDP - GRASS Documentation Project</a>
 <br>
-<hr>
-Download "<b>Binaries</b>": if you want to install ready-to-use GRASS.<br>
-Download "<b>Source Code</b>": if you want to develop own GRASS extensions or run
-GRASS on a special computer platform.<br>
-<hr><b>Old GRASS versions:</b>
+<h3>Old GRASS versions:</h3>
 <ul>
 <li>GRASS 5.7 [old] <a href="../grass57/">Download GRASS 5.7</a>
 <li>GRASS 5.4 [old] <a href="../grass54/">Download GRASS 5.4</a>
More information about the grass-web
