[GRASSweb-list]markus: web/announces announce_grass602.html,1.10,1.11
grass at intevation.de
Wed Jan 25 12:17:12 EST 2006
Author: markus
Update of /grassrepository/web/announces
In directory doto:/tmp/cvs-serv26227
Modified Files:
Log Message:
GRASS_INT_ZLIB fix added; cleanup
Index: announce_grass602.html
RCS file: /grassrepository/web/announces/announce_grass602.html,v
retrieving revision 1.10
retrieving revision 1.11
diff -u -d -r1.10 -r1.11
--- announce_grass602.html 11 Jan 2006 10:43:24 -0000 1.10
+++ announce_grass602.html 25 Jan 2006 17:17:10 -0000 1.11
@@ -66,26 +66,32 @@
(see ChangeLog for details and the previous announcements as well)
<ul>
-<li> Include files fixed (in 6.0.2RC2)
-<li> FreeBSD portability fixes (in 6.0.2RC2)
-<li> changed year to 2006 (in 6.0.2RC3)
-<li> bugfix for 'builddemolocation target' in Makefile when building as root (RPMs etc) (in 6.0.2RC4)
-<li> bugfix to remove leftover object files (in 6.0.2RC4)
-<li> no longer ring the bell for messages which just inform
-<li> gis library: fixed (rare) bug where row pointers were enlarged to 8 bytes, overwriting the beginning of the data
-<li> sites library: bugfix for gstat interface
-<li> Documentation: updates
-<li> New mapset creation: pre-define DBF default settings for attributes
-<li> ps.map: region command fixed
-<li> r.fillnulls: extended ring to 3 pixels, MASK management fix; resolution < 1 fix
-<li> r.regression.line: functional now
-<li> r.stats: fixed segmentation fault in certain cases
-<li> v.in.e00: do build the topology
-<li> v.transform: fixed file browser button (after 6.0.2RC4)
-<li> Scripts: Fixed remaining calculation problems (awk related) in scripts for various locales
-<li> Scripts: awk test fixed (in 6.0.2RC2)
+<li>Source code quality/libraries:
+<ul>
+ <li> Include header files fixed (in 6.0.2RC2)
+ <li> FreeBSD portability fixes (in 6.0.2RC2)
+ <li> changed year to 2006 (in 6.0.2RC3)
+ <li> bugfix for 'builddemolocation target' in Makefile when building as root (RPMs etc) (in 6.0.2RC4)
+ <li> bugfix to remove leftover object files (in 6.0.2RC4)
+ <li> no longer ring the bell for messages which just inform
+ <li> gis library: fixed (rare) bug where row pointers were enlarged to 8 bytes, overwriting the beginning of the data
+ <li> gis library: fixed zlib compression bug for tiny raster integer maps if GRASS_INT_ZLIB activated (after 6.0.2RC4)
+ <li> sites library: bugfix for gstat interface
+</ul>
+<li> Modules/Scripts:
+<ul>
+ <li> Documentation: updates
+ <li> New mapset creation: pre-define DBF default settings for attributes
+ <li> ps.map: region command fixed
+ <li> r.fillnulls: extended ring to 3 pixels, MASK management fix; resolution < 1 fix
+ <li> r.regression.line: functional now
+ <li> r.stats: fixed segmentation fault in certain cases
+ <li> v.in.e00: do build the topology
+ <li> v.transform: fixed file browser button (after 6.0.2RC4)
+ <li> Scripts: Fixed remaining calculation problems (awk related) in scripts for various locales
+ <li> Scripts: awk test fixed (in 6.0.2RC2)
+</ul>
</ul>
<P>
For a more comprehensive list of changed modules see the
<a href="../grass60/source/">ChangeLog_6.0.2RC2.gz</a>.</p>
More information about the grass-web
