[GRASSweb-list] scott: web/grass50 index.html,1.34,1.35
grass at intevation.de
Fri Feb 9 13:11:22 EST 2007
Author: scott
Update of /grassrepository/web/grass50
In directory doto:/tmp/cvs-serv30656/grass50
Modified Files:
Log Message:
change bug tracker links to new tracker / tracker info
Index: index.html
RCS file: /grassrepository/web/grass50/index.html,v
retrieving revision 1.34
retrieving revision 1.35
diff -u -d -r1.34 -r1.35
--- index.html 10 Jan 2005 09:42:19 -0000 1.34
+++ index.html 9 Feb 2007 18:11:20 -0000 1.35
@@ -89,7 +89,8 @@
GRASS 5.0.x has been tested on Linux, MacOSX, SUN, WindowsNT/2000/XP and Silicon
Graphics Irix systems. Many people use it for daily production. HOWEVER,
-there are likely still some <a href=http://intevation.de/rt/webrt?q_queue=grass>bugs</a> to be worked
+there are likely still some <a href="http://intevation.de/rt/webrt?q_queue=grass">bugs</a>
+ to be worked
out.
<a name="manuals"></a>
@@ -108,7 +109,7 @@
<li>List of <a href="http://intevation.de/rt/webrt?q_queue=grass">known bugs
in this GRASS 5.0.x version</A>. Your help to fix these bugs is highly appreciated. If you find
a bug, please check the list if it is already known. If not, you are kindly
- requested to report the bug(s) to use our new <a href="../bugtracking/bugreport.html">bug report form</a>
+ requested to report the bug(s) to use our new <a href="../bugtracking/index.php">bug report system</a>
</ul>
<a name="cluster"></a>
More information about the grass-web
