[GRASSweb-list] scott: web/grass54 index.html,1.6,1.7
grass at intevation.de
Fri Feb 9 13:11:22 EST 2007
Author: scott
Update of /grassrepository/web/grass54
In directory doto:/tmp/cvs-serv30656/grass54
Modified Files:
Log Message:
change bug tracker links to new tracker / tracker info
Index: index.html
RCS file: /grassrepository/web/grass54/index.html,v
retrieving revision 1.6
retrieving revision 1.7
diff -u -d -r1.6 -r1.7
--- index.html 13 Aug 2006 21:15:26 -0000 1.6
+++ index.html 9 Feb 2007 18:11:20 -0000 1.7
@@ -88,7 +88,7 @@
<li>List of <a href="http://intevation.de/rt/webrt?q_queue=grass">known bugs
in this GRASS 5.4.x version</A>. Your help to fix these bugs is highly appreciated. If you find
a bug, please check the list if it is already known. If not, you are kindly
- requested to report the bug(s) to use our new <a href="../bugtracking/bugreport.html">bug report form</a>
+ requested to report the bug(s) to use our new <a href="../bugtracking/index.php">bug report form</a>
</ul>
<a name="cluster"></a>
More information about the grass-web
