[GRASSweb-list] hamish: web/grass62/binary/mswindows README.html, 1.9, 1.10
grass at intevation.de grass at intevation.de
Thu Feb 15 18:49:19 EST 2007
Author: hamish
Update of /grassrepository/web/grass62/binary/mswindows
In directory doto:/tmp/cvs-serv11645
Modified Files:
	README.html
Log Message:
fix cygwin.bat dir, add more internal links
Index: README.html
RCS file: /grassrepository/web/grass62/binary/mswindows/README.html,v
retrieving revision 1.9
retrieving revision 1.10
diff -u -d -r1.9 -r1.10
--- README.html	15 Feb 2007 23:39:12 -0000	1.9
+++ README.html	15 Feb 2007 23:49:17 -0000	1.10
@@ -61,10 +61,12 @@
 <P><BR>
 To start GRASS, double-click on the Cygwin icon and run "<tt>startx</tt>" at
 the command prompt. This will start X-Windows and open a new xterm window.
-At the xterm prompt type "<tt>grass62</tt>". To start GRASS from an icon on
-the Desktop, see below.
+At the xterm prompt type "<tt>grass62</tt>".
 <P>
-In case of problems see the troubleshooting section below.
+To start GRASS from an icon on the Desktop, <a href="#icon">see below</a>.
+<P>
+In case of problems see the <a href="#trouble">troubleshooting section</a>
+below.
 <br><br>
 <hr>
@@ -97,9 +99,9 @@
 <a name="icon"></a>
 <h4>Starting Cygwin GRASS from an icon on the desktop:</h4>
-copy c:\cygwin.bat to c:\cygwin_grass.bat
+copy c:\cygwin\cygwin.bat to c:\cygwin\cygwin_grass.bat
 <P>
-edit c:\cygwin_grass.bat so it looks like this:
+edit c:\cygwin\cygwin_grass.bat so it looks like this:
   (add "set GRASS_AUTOSTART=1" and "-c startx")
 <BR>
 <DD><PRE>
@@ -153,7 +155,7 @@
 that contains the missing file at the <a href="http://cygwin.com/packages/">
 Cygwin package search page</a>. Re-run the Cywgin installer to load the
 missing package; it will have remembered your earlier selections.
-Feel free to file a bug report as well (see below).
+Feel free to file a bug report as well (<a href="#bugs">see below</a>).
 <br><br>
 <hr>
@@ -166,7 +168,8 @@
 <P>
 The winGRASS package is just a .tar.bz2 file. It can be extracted into Cygwin's
-root directory (or use setup.ini as explained in above external notes),
+root directory (or use setup.ini as explained in <a href="#prereq">above</a>
+external notes),
 e.g.:
 <DD>
@@ -182,7 +185,8 @@
 Regarding external dependencies: the only dependencies which aren't
 provided by Cygwin are GDAL and Tcl/Tk. They can be downloaded
 above and they have to be extracted into Cygwin's root directory
-as well (or use setup.ini as explained in above external notes).
+as well (or use setup.ini as explained in <a href="#prereq">above</a>
+external notes).
 <BR><BR>
 <hr>
More information about the grass-web mailing list
