[GRASS-web] Slovakia mirror
Pavol Cvengros
pavol.cvengros at primeinteractive.net
Tue Mar 24 03:43:19 EDT 2009
Hello Markus,
I have changed my rsync to mirror from grass.osgeo.org.
Best regards,
Pavol
On 23. 3. 2009 21:51, Markus Neteler wrote:
> Hello Pavol,
> I see that http://grass.sk/index.php
> is lagging behind for 3 days... maybe you need to read from grass.osgeo.org?
> The rsync server responds well.
> Best regards,
> Markus
> On Sun, Mar 22, 2009 at 12:18 PM, Pavol Cvengros
> <pavol.cvengros at primeinteractive.net> wrote:
>> Hello,
>> rsync server on my server is set. Only one repository available from sync
>> and that is grass. Maximum 20 parallel connections.
>> Please test it and if everything will be ok I would like to apply for tier 1
>> mirror server.
>> Rsync server: grass.sk
>> Best regards,
>> Pavol
>> On 11. 3. 2009 9:22, Markus Neteler wrote:
>> Hello Pavol,
>> On Wed, Mar 11, 2009 at 7:48 AM, Pavol Cvengros
>> Hello,
>> I am running Slovakia mirror on my private server with courtesy of Prime
>> Interactive Ltd. for a long time on domain grass.sk
>> I found that you are looking for tier 1 mirrors. What is needed to become
>> one? Is the only one condition to run rsync server to provide mirroring
>> capabilities for tier 2 server?
>> that's right! Just "be open", say, permit others to rsync from you.
>> All this originates from the times that the master site was grass.itc.it
>> with
>> limited bandwiths. grass.osgeo.org is well connected (thanks to
>> telascience.org)
>> so that we reach 2.x TB (!) peaks per months.
>> However, mirrors don't harm and we prefer a semi-decentralized
>> infrastructure
>> in case the North Atlantic or Pacific network bones get cut. Still we'd
>> remain
>> online :)
>> If you have enough bandwidth you may enable others to rsync from you.
>> Then please ping us here to update the mirror list (next of your mails will
>> go through directly).
>> Best regards,
>> Markus
More information about the grass-web
